Can't save vba project
JanneArvid
JanneArvid
I can't save my vba project after a change in the code, i get a prompt alert that the file is Read only.
The file is located on my C: disc and in Autocad 2022 i added the folder in Trusted location and is not a synchronized folder. The file properties is set to not read only.
Any ideas?
Ed__Jobe
AutoCAD likes Trusted Locations to be read-only. You can put your dvb in a folder that is read/write enabled, but you will have to respond to a prompt to allow that. As to your current changes, you can copy the module's code to a text file and then after you fix the write issue, paste it back to the dvb.
Ed
How to post your code.
