Can objectviewer save images automatically?
Is it possible with VBA? Or .NET, javascript, python?
Can you manipulate child windows from parent window?
The objectviewer window looks like mordal.
I select objects in VBA and open objectviewer, but I can not save images automatically. It's good in other languages, so it would be helpful if you have any hints.
Thank you.
norman.yuan
I do not believe the Object Viewer showing in AutoCAD exposes APIs (be it COM, or .NET, or whatever programming platforms) for customization by outsiders, but I think it is internally (to other AutoCAD vertical products)  customize-able, because I can see the same viewing effect being used in different AutoCAD verticals, such as in Acad Architecture, as mentioned here. That is, the object viewing functionality must be wrapped in a component and with interface being exposed, so that it can be re-used in different occasions. It is just not exposed to outside world (outside of Autodesk).
Since you are asking in AutoCAD VBA forum, I am sure there is no way to manipulate/control it with AutoCAD VBA code.
Norman Yuan
Drive CAD With Code
Thank you for your reply.
I understand very well that you say there is no way in VBA. Thanks to you, I was able to make that feeling stronger now.
If automation is possible, ObjectARX may be the closest. Or it may be a screen operation in Windows leaving AutoCAD. Just in case, let's ask questions on the board of ObjectARX. This question closes.
Thank you.
