Terry W. Dotson a écrit :
mcguirepm wrote:
Is there a way to call a lisp routine from a VBA program?
You can use SendCommand but you may have synchronize problems as (from
best I remember) it doesn't wait for it to execute.
Also search these groups for VL.Application, but it has it's own set of
problems.
Good Luck, Terry
Try the VLAX class from Franck Okendo :
'VERSION 1.0 CLASS
'BEGIN
' MultiUse = -1 'True
'End
'Attribute VB_Name = "VLAX"
'Attribute VB_GlobalNameSpace = False
'Attribute VB_Creatable = False
'Attribute VB_PredeclaredId = False
'Attribute VB_Exposed = False
'VLAX.CLS v1.4 (Last updated 8/27/2001)
' Copyright 1999-2001 by Frank Oquendo
' Permission to use, copy, modify, and distribute this software
' for any purpose and without fee is hereby granted, provided
' that the above copyright notice appears in all copies and
' that both that copyright notice and the limited warranty and
' restricted rights notice below appear in all supporting
' documentation.
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. THE AUTHOR
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
' UNINTERRUPTED OR ERROR FREE.
' Use, duplication, or disclosure by the U.S. Government is subject to
' restrictions set forth in FAR 52.227-19 (Commercial Computer
' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
' (Rights in Technical Data and Computer Software), as applicable.
' VLAX.cls allows developers to evaluate AutoLISP expressions from
' Visual Basic or VBA
' Notes:
' All code for this class module is publicly available througout
various posts
' at
news://discussion.autodesk.com/autodesk.autocad.customization.vba.
I do not
' claim copyright or authorship on code presented in these posts, only
on this
' compilation of that code. In addition, a great big "Thank you!" to
Cyrille Fauvel
' demonstrating the use of the VisualLISP ActiveX Module.
' Dependencies:
' Use of this class module requires the following application:
' 1. VisualLISP
Private vl As Object
Private VLF As Object
'Private Sub Class_Initialize()
'Set vl = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
' For AutoCAD 2004
'Set vl =
ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
'Set VLF = vl.ActiveDocument.Functions
'End Sub
If Left(ThisDrawing.Application.Version, 2) = "15" Then
ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
Set vl = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
ElseIf Left(ThisDrawing.Application.Version, 2) = "17" Then
ElseIf Left(ThisDrawing.Application.Version, 2) = "18" Then
'error occurs
End Sub
Private Sub Class_Terminate()
Set VLF = Nothing
Set vl = Nothing
End Sub
Public Function EvalLispExpression(lispStatement As String)
Dim sym As Object, ret As Object, retVal
Set sym = VLF.Item("read").funcall(lispStatement)
On Error Resume Next
retVal = VLF.Item("eval").funcall(sym)
If Err Then
EvalLispExpression = ""
Else
EvalLispExpression = retVal
End Function
Public Sub SetLispSymbol(symbolName As String, Value)
Dim sym As Object, ret, symValue
symValue = Value
Set sym = VLF.Item("read").funcall(symbolName)
ret = VLF.Item("set").funcall(sym, symValue)
EvalLispExpression "(defun translate-variant (data) (cond ((= (type
data) 'list) (mapcar 'translate-variant data)) ((= (type data)
'variant)(translate-variant (vlax-variant-value data))) ((= (type data)
'safearray)(mapcar 'translate-variant (vlax-safearray->list data)))
(t data)))"
EvalLispExpression "(setq " & symbolName & "(translate-variant
" & symbolName & "))"
EvalLispExpression "(setq translate-variant nil)"
End Sub
Public Function GetLispSymbol(symbolName As String)
symValue = Value
GetLispSymbol = VLF.Item("eval").funcall(sym)
End Function
Public Function GetLispList(symbolName As String) As Variant
Dim sym As Object, list As Object
Dim count, elements(), I As Long
Set list = VLF.Item("eval").funcall(sym)
count = VLF.Item("length").funcall(list)
ReDim elements(0 To count - 1) As Variant
For I = 0 To count - 1
elements(I) = VLF.Item("nth").funcall(I, list)
Next
GetLispList = elements
End Function
Public Sub NullifySymbol(ParamArray symbolName())
Dim I As Integer
For I = LBound(symbolName) To UBound(symbolName)
EvalLispExpression "(setq " & CStr(symbolName(I)) & " nil)"
Next
End Sub
