Call Lisp from VBA
Call Lisp from VBA
Call Lisp from VBA
Is there a way to call a lisp routine from a VBA program?
You can use SendCommand but you may have synchronize problems as (from
best I remember) it doesn't wait for it to execute.
Also search these groups for VL.Application, but it has it's own set of
problems.
Good Luck, Terry
problems.
Good Luck, Terry
Try the VLAX class from Franck Okendo :
'VERSION 1.0 CLASS
'BEGIN
'  MultiUse = -1  'True
'End
'Attribute VB_Name = "VLAX"
'Attribute VB_GlobalNameSpace = False
'Attribute VB_Creatable = False
'Attribute VB_PredeclaredId = False
'Attribute VB_Exposed = False
'VLAX.CLS v1.4 (Last updated 8/27/2001)
' Copyright 1999-2001 by Frank Oquendo
' Permission to use, copy, modify, and distribute this software
' for any purpose and without fee is hereby granted, provided
' that the above copyright notice appears in all copies and
' that both that copyright notice and the limited warranty and
' restricted rights notice below appear in all supporting
' documentation.
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. THE AUTHOR
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
' UNINTERRUPTED OR ERROR FREE.
' Use, duplication, or disclosure by the U.S. Government is subject to
' restrictions set forth in FAR 52.227-19 (Commercial Computer
' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
' (Rights in Technical Data and Computer Software), as applicable.
' VLAX.cls allows developers to evaluate AutoLISP expressions from
' Visual Basic or VBA
' Notes:
' All code for this class module is publicly available througout
various posts
' at news://discussion.autodesk.com/autodesk.autocad.customization.vba.
I do not
' claim copyright or authorship on code presented in these posts, only
on this
' compilation of that code. In addition, a great big "Thank you!" to
Cyrille Fauvel
' demonstrating the use of the VisualLISP ActiveX Module.
' Dependencies:
' Use of this class module requires the following application:
' 1. VisualLISP
Private vl As Object
Private VLF As Object
'Private Sub Class_Initialize()
'Set vl = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
' For AutoCAD 2004
'Set vl =
ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
'Set VLF = vl.ActiveDocument.Functions
'End Sub
If Left(ThisDrawing.Application.Version, 2) = "15" Then
ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
Set vl = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
ElseIf Left(ThisDrawing.Application.Version, 2) = "17" Then
ElseIf Left(ThisDrawing.Application.Version, 2) = "18" Then
'error occurs
End If
End Sub
Private Sub Class_Terminate()
Set VLF = Nothing
Set vl = Nothing
End Sub
Public Function EvalLispExpression(lispStatement As String)
Dim sym As Object, ret As Object, retVal
Set sym = VLF.Item("read").funcall(lispStatement)
On Error Resume Next
retVal = VLF.Item("eval").funcall(sym)
If Err Then
EvalLispExpression = ""
Else
EvalLispExpression = retVal
End If
End Function
Public Sub SetLispSymbol(symbolName As String, Value)
Dim sym As Object, ret, symValue
symValue = Value
Set sym = VLF.Item("read").funcall(symbolName)
ret = VLF.Item("set").funcall(sym, symValue)
EvalLispExpression "(defun translate-variant (data) (cond ((= (type
data) 'list) (mapcar 'translate-variant data)) ((= (type data)
'variant)(translate-variant (vlax-variant-value data))) ((= (type data)
'safearray)(mapcar 'translate-variant (vlax-safearray->list data)))
(t data)))"
EvalLispExpression "(setq " & symbolName & "(translate-variant
" & symbolName & "))"
EvalLispExpression "(setq translate-variant nil)"
End Sub
Public Function GetLispSymbol(symbolName As String)
symValue = Value
GetLispSymbol = VLF.Item("eval").funcall(sym)
End Function
Public Function GetLispList(symbolName As String) As Variant
Dim sym As Object, list As Object
Dim count, elements(), I As Long
Set list = VLF.Item("eval").funcall(sym)
count = VLF.Item("length").funcall(list)
ReDim elements(0 To count - 1) As Variant
For I = 0 To count - 1
elements(I) = VLF.Item("nth").funcall(I, list)
Next
GetLispList = elements
End Function
Public Sub NullifySymbol(ParamArray symbolName())
Dim I As Integer
For I = LBound(symbolName) To UBound(symbolName)
EvalLispExpression "(setq " & CStr(symbolName(I)) & " nil)"
Next
End Sub
