Here is one solution. Look at the attached picture to see the result. 4th point is cross point of two vectors. It's easy to calculate direction angle between first and third point of the input line and based on this angle and length of the side of the square you can calculate the 4th point. We will have 4 different cases depending on wich quadrant lies the vector between 1st and 3rd point.
Option Explicit
Public Const PI = 3.14159265358979
Sub testche()
Dim line As AcadLWPolyline '' input line (constructed by 3 points)
Dim obj As AcadObject
Dim var As Variant
On Error Resume Next
ThisDrawing.Utility.GetEntity obj, var, "Select line: "
If (TypeOf obj Is AcadLWPolyline) Then
Set line = obj
line = modifyLine(line)
End If
End Sub
'' this method returns closed polyline
Private Function modifyLine(inputLine As AcadLWPolyline) As AcadLWPolyline
Dim line As AcadLWPolyline: Set line = inputLine
Dim pnt1 As Variant: pnt1 = line.Coordinate(0) '' first vertex
Dim pnt2 As Variant: pnt2 = line.Coordinate(1) '' second vertex
Dim pnt3 As Variant: pnt3 = line.Coordinate(2) '' third vertex
Dim pnt4(0 To 1) As Double '' fourth vertex
Dim s As Double: s = getDistance(pnt1(1), pnt1(0), pnt2(1), pnt2(0))
Dim r As Double: r = 50 '' this is always 45 degrees (50 gon)
Dim a1 As Double: a1 = getDirectionAngle(pnt1(1), pnt1(0), pnt3(1), pnt3(0))
Dim a2 As Double: a2 = getDirectionAngle(pnt1(1), pnt1(0), pnt2(1), pnt2(0))
'' we have four different cases according to rotation of the input line
If a1 < 200 Then
If a1 < a2 Then
a1 = a1 - r
Else
a1 = a1 + r
End If
Else
If a1 < a2 Then
a1 = a1 - r
Else
a1 = a1 + r
End If
End If
'' coordinates of the 4th vertex
pnt4(1) = pnt1(1) + s * Math.Cos(a1 * PI / 200)
pnt4(0) = pnt1(0) + s * Math.Sin(a1 * PI / 200)
line.AddVertex 3, pnt4
line.Closed = True
line.Update
modifyLine = line
End Function
Private Function getDistance(ByVal x1 As Double, ByVal y1 As Double, ByVal x2 As Double, ByVal y2 As Double)
getDistance = Math.Sqr(Math.Abs(x2 - x1) ^ 2 + Math.Abs(y2 - y1) ^ 2)
End Function
Private Function getDirectionAngle(ByVal x1 As Double, ByVal y1 As Double, ByVal x2 As Double, ByVal y2 As Double) As Double
Dim alfa As Double
If x2 - x1 > 0 And y2 - y1 > 0 Then
alfa = Math.Atn(Abs(y2 - y1) / Abs(x2 - x1)) * 200 / PI
ElseIf x2 - x1 < 0 And y2 - y1 > 0 Then
alfa = 200 - alfa
ElseIf x2 - x1 < 0 And y2 - y1 < 0 Then
alfa = 200 + alfa
ElseIf x2 - x1 > 0 And y2 - y1 < 0 Then
alfa = 400 - alfa
ElseIf x2 - x1 = 0 And y2 - y1 > 0 Then
alfa = 100
ElseIf x2 - x1 < 0 And y2 - y1 = 0 Then
alfa = 200
ElseIf x2 - x1 = 0 And y2 - y1 < 0 Then
alfa = 300
ElseIf x2 - x1 > 0 And y2 - y1 = 0 Then
alfa = 0
End If
getDirectionAngle = alfa
End Function
