Break from VB
Break from VB
Message 1 of 8
Break from VB
I need send a break to autocad (or esc) with sendcommand method (or similar)
but don´t works to end any pending command.
I use acadobj.sendcommand(chr(27)) but this don´t work.
Any ideas?
Than
Replies (7)
Message 2 of 8
Sendcommands only work when the acadscreen is visible and active. But I
assume that this is the case. When do you want to cancel? Do you want to
cancel a running code? Or do you want to interrupt an user action when an
event is triggered?
"Roddy" wrote in message
news:93AD25005330ED2364EA55EFDD46752B@in.WebX.maYIadrTaRb...
similar)
> Any ideas?
> Than
Message 3 of 8
Public Sub Escape()
'Simulate the Escape key being pressed
On Error Resume Next
ThisDrawing.ActiveDocument.SendCommand Chr$(27)
End Sub
Veign
www.veign.com
Code Samples & Sample Projects
http://www.veign.com/information/application/info_app.html
Submit Your Best Code (you keep the rights)
http://www.veign.com/information/application/code_submit.html
similar)
> Any ideas?
> Than
Message 4 of 8
I need to stop pendings commands like zoom, to permit to select object from
code in VB.
Thanks...
"Joeri Tuyn" escribió en el mensaje
news:18EC0726255090BCF579F64B8C6A47AC@in.WebX.maYIadrTaRb...
> event is triggered?
> similar)
> > Any ideas?
> > Than
Message 5 of 8
Ed__Jobe
Using SendCommand may not work when you want it to due to the fact that it is asyncronous. Try the following function.
Public Sub CancelCommand()
SendKeys "{ESC}"
End Sub
Ed
How to post your code.
Message 6 of 8
Hmm, tough one. VBA apps won't start when there are
still commands in progress. So no command can be send in a way through vba. No
sendkeys and no sendcommand. If you start your VBA-application with a
button, you can put a cancel command in the commandline behind the button. Or if
you start it through a lisp routine, put a cancel in the routine before starting
you're application. If you start an application with an event in VBA you might
be able to cancel it with sendkeys or sendcommand but I don't think that will
work....
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Using
    SendKeys "{ESC}"
End Sub
Message 7 of 8
It sounds like you're trying to initiate a macro from the command line
while in the middle of a command. If that's the case, then I'd say
that's a problem. But it's not just with vba, it's with any acad command
. Even transparent commands can't be initiated from the prompt while in
the middle of something else. You have to kill it with the esc key or
with a ^C^C from a button. But that's normal behaviour.
-Josh
Joeri Tuyn wrote:
> Hmm, tough one. VBA apps won't start when there are still commands in
> progress. So no command can be send in a way through vba. No sendkeys
> and no sendcommand. If you start your VBA-application with a button, you
> can put a cancel command in the commandline behind the button. Or if you
> starting you're application. If you start an application with an event
> in VBA you might be able to cancel it with sendkeys or sendcommand but I
> don't think that will work....
> "Ed_Jobe" wrote in message news:f0e512e.3@WebX.maYIadrTaRb...
> SendKeys "{ESC}"
> End Sub
Message 8 of 8
To correct myself, you can use transparents from the command prompt but
only with the use of '_
You can't execute a zoom in the middle of a line with Z straight from
the pgp file, you have to use '_Z
