Blocks *D....
Blocks *D....
Blocks *D....
When I remove the blocks from drawing by command "ThisDrawing.Blocks (name) Delete" then it is automaticly created block with name " *D...." for example *D170. You can find these blocks on purge list in blocks section.
Does anyone know why these blocks are created and how remove these blocks using VBA without command PURGE ?
This problem I have only with blocks which containing dimensions.
Alfred.NESWADBA
that are unnamed blocks. And these blocks are used internally by AutoCAD to have some Elementtypes displayed in different ways (like dimensions, dynamic blocks, in early AutoCAD-times also for hatches).
So you may get it deleted but AutoCAD will recreate them when it needs it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
