Block Viewer for AutoCAD 2008
I'm looking for an ocx te create a block viewer in my AutoCAD VBa code. I
have searched the Internet but can't find a proper one. What must it do,
well very simple, just show a 2D Block in an Image in a dialog.
Has anyone experience with this?
TIA
/Leo
Quite a while ago I made an application for making a block library that was in a database. What I did for images was make export WMF (with and without backgrounds). This routine actually resizes the application window to get a the smallest bounding box for the WMF image. WMF works well with VBA userforms. Lots of code in here you don't need, this was part of a detail database cataloging application. Here is a snip of code:
'~~~start code, after you have wblocked the objects
'you wish to make an image of
Set wBlkDwg = Application.Documents.Open(catDtlPath & catDetailID & ".dwg")
For Each ent In ssetUserSel
ent.Move Origin, ZeroPnt
'moving all objects relative of origin -disregard
Next
wBlkDwg.Application.ZoomExtents
'chngFld wBlkDwg, "DTL_ID", catDetailID
'chngFld wBlkDwg, "Entered_By", Environ("USERNAME")
acdPref.OpenSave.SavePreviewThumbnail = True
wBlkDwg.PurgeAll
Sleep (250)
wBlkDwg.Save
Sleep (250)
'create new selection set in wblkdwg
Set ssetUserSel = wBlkDwg.SelectionSets.Add("SSdtlCat")
rectMax(0) = rectMax(0) - 1
If ssBBox = False Then GoTo errCaseC
ssetUserSel.Select acSelectionSetWindow, rectMax, rectMin
Sleep (250)
'wmf export with picture cropping, with and without backgrounds
wBlkDwg.width = Round(wBlkDwg.width / (rectMax(0) - rectMin(0))) * (rectMax(1) - rectMin(1))
wBlkDwg.Application.ZoomWindow rectMin, rectMax
wBlkDwg.Application.Update
wBlkDwg.Regen acActiveViewport
wBlkDwg.SetVariable "WMFBKGND", 0
wBlkDwg.Export catWmfPath & catDetailID & "-OFF", "WMF", ssetUserSel
Sleep (250)
wBlkDwg.SetVariable "WMFBKGND", 1
wBlkDwg.Export catWmfPath & catDetailID & "-ON", "WMF", ssetUserSel
'~~~end code
Here is dirty way to make SLD images: (qm = """")
wBlkDwg.SendCommand ("(command " & qM & "mslide" & qM & _
" " & qM & Replace(catSldPath, "\", "\\") & _
Replace(catDetailID, "\", "\\") & ".sld" & qM & ")" & vbCr)
Hope it helps, no time to explain further. I'm sure there are lots of ways to do this.
Hi!
Thnx for your input It is not really what I'm searching for. I'm more
looking for a realtime Block Viewer. Via a dialog a user can give options
which are translated in a Block and I want to show the result directly in
teh dialog.
/Leo
schreef in bericht news:5822422@discussion.autodesk.com...
Next
wBlkDwg.PurgeAll
Sleep (250)
wBlkDwg.Save
Sleep (250)
Sleep (250)
Sleep (250)
'~~~end code
to do this.
I created a block manager a while ago with a preview window. Its quite involved and required a fair bit of coding. I managed to get the help I needed by searching for drawing preview.
I would post the code but its all over the place in my forms and modules.
Daniel
