block names
block names
Message 1 of 9
block names
Using autocad14 how do I go through every block in a drawing and if the
block name is over 31 characters I want to rename it to "block1", "block2",
etc..... Any help is appreciated.
Rob
Replies (8)
Message 2 of 9
This code should do the task. It does NOT however check to see if there
already is a block named "BlockX" before it renames one of the blocks:
Option Explicit
Sub RenameBlocks()
Dim oBlock As AcadBlock
Dim oBlocks As AcadBlocks
Dim intCounter As Integer
Set oBlocks = ThisDrawing.Blocks
intCounter = 1
For Each oBlock In oBlocks
If Not oBlock.IsXRef And Not oBlock.IsLayout Then
If Len(oBlock.Name) > 31 Then
oBlock.Name = "Block" & CStr(intCounter)
intCounter = intCounter + 1
End If
End If
Next
End Sub
Trond Hasse Lie
Thrane Information Systems
Norway
"Hairball" wrote in message
news:ef344b5.-1@WebX.SaUCah8kaAW...
"block2",
> Thanks,
> Rob
Message 3 of 9
This will not do you much good since you cannot have a block name of more
than 31 characters in AutoCAD R14. Not sure what you are trying to acheive.
Joe
"Trond Hasse Lie" wrote in message
news:ef344b5.0@WebX.SaUCah8kaAW...
> Option Explicit
> Sub RenameBlocks()
> intCounter = 1
> End If
> End If
> Next
> End Sub
> Trond Hasse Lie
> Norway
> "block2",
> > Thanks,
> > Rob
Message 4 of 9
🙂 I didn't the AutoCAD 14 bit..... but it MIGHT be a typo?
Trond Hasse Lie
Norway
"Joe Sutphin" wrote in message
news:ef344b5.1@WebX.SaUCah8kaAW...
acheive.
> Joe
> > Option Explicit
> > Sub RenameBlocks()
> > intCounter = 1
> > End If
> > End If
> > Next
> > End Sub
> > Trond Hasse Lie
> > Norway
the
> > "block2",
> > > Thanks,
> > > Rob
Message 5 of 9
no, it's not a typo. if you convert a 2000 drawing to 14 it will keep the
block names too long so at work i can't xref things in. that's why i'm
making this program.
Rob
Message 6 of 9
this doesn't work. is it different for autocad r14?
Rob
Trond Hasse Lie wrote in message
> Option Explicit
> Sub RenameBlocks()
> intCounter = 1
> End If
> End If
> Next
> End Sub
> Trond Hasse Lie
> Norway
> "block2",
> > Thanks,
> > Rob
Message 7 of 9
The code doesn't work in 14. As far as I can see, the BlockRenaming must be
done in 2000 before saving to 14 format.
And... When I tested, I made a block in 2000 with a 32 character name. When
opening the drawing in 14, the blocks name consisted of only the 26 first
charaters. Don't know why.....
Trond Hasse Lie
Norway
"Rob" wrote in message
news:ef344b5.4@WebX.SaUCah8kaAW...
> Rob
> > Option Explicit
> > Sub RenameBlocks()
> > intCounter = 1
> > End If
> > End If
> > Next
> > End Sub
> > Trond Hasse Lie
> > Norway
the
> > "block2",
> > > Thanks,
> > > Rob
Message 8 of 9
and if you try to xref that drawing into another drawing it says the block
name is too long. so what's going on?
Rob
news:4B8B4A7113723585ED51AF5BE6010C5A@in.WebX.SaUCah8kaAW...
be
When
> Trond Hasse Lie
> Norway
> > Rob
there
> > > Option Explicit
> > > Sub RenameBlocks()
> > > intCounter = 1
> > > End If
> > > End If
> > > Next
> > > End Sub
> > > Trond Hasse Lie
> > > Norway
> the
> > > "block2",
> > > > Thanks,
> > > > Rob
Message 9 of 9
Autodesk released a patch to R14, called BindTPtch.arx, which neatly
addressed this problem.
see (watch for word wrap):
http://www3.autodesk.com/adsk/support/techdoc/0,,116068--273818-0_21837,00.h
tml
R. Robert Bell, MCSE
Xtending the Power
www.acadx.com
news:ef344b5.3@WebX.SaUCah8kaAW...
| Rob
