BatchFile text size example
'With help from one and all I got a Batch file going. This
'one gets a Dir and new textsize from the user, then modifys the text,
'and resaves each dwg. I did 80 dwg's with it. I got pretty interested
'in batch files doing 'this. If anyone has any other nice batch files
'kicking around I would enjoy to receive them here or at my own e-mail
'Thanks all, and good luck! jim kitts
'Paste this into a module, then 'vbarun' at the command line
Dim TextSize As String 'load in 'SetCadBatch()
'TextSize used in SizeTxt()
Sub SetCadBatch()
'Ck if a live ACADDoc exists or make one
'get data from input boxs and trap errors
'jimbo\3:00 pm 3/6/00
'C:\JimJunk\Fundy4\X2 'my Fundy Park test file
'if user killed all dwg's add
'a blank to prevent an error
If Application.Documents.Count = 0 Then
Dim docObjNew As AcadDocument
Set docObjNew = Application.Documents.Add
End If
'at least one dwg is loaded
'so chose a drawing file
Dim dwgName As String
Dim msg As String: Dim title As String
msg = "Where is the Batch Directory?"
title = "Give it to me, baby!"
Dim inDir As String
inDir = InputBox(msg, title)
'check for a cancel
If inDir = "" Then
Exit Sub
End If
'ck if file exists if not, then exit
Dim tmp As String
temp = Dir$(inDir & "\*.dwg")
If temp = "" Then
MsgBox "Ain't no dwg here!"
Exit Sub
End If
msg = "What size do you want your text?"
title = "New Text Size"
TextSize = InputBox(msg, title) 'Dim in Declare
If TextSize = "" Then
Exit Sub 'trap cancel
End If
If Not IsNumeric(TextSize) Then 'trap text
MsgBox "Gotta give a number..."
Exit Sub
End If '
'loop through the files:
Dim filenom As String
filenom = Dir$(inDir & "\*.dwg")
Do While filenom <> ""
Dim WholeFile As String
WholeFile = inDir & "\" & filenom
'do somthin next
DoEvents
ThisDrawing.Application.Documents.Open WholeFile
DoEvents
Call SizeTxt 'reach out for the main routine
ThisDrawing.Close (True) ' gives a save
DoEvents
'end do somethin part
'set tmp to loop through again
filenom = Dir$
Loop
End Sub
Private Sub SizeTxt()
Dim elem As Object
Dim found As Boolean
' this is from the Acad examples
'Cycle through the entities in the ModelSpace
For Each elem In ThisDrawing.ModelSpace
With elem
If (.EntityName = "AcDbText") Or (.EntityName = "AcDbMText") Then
' Change the height of the text entity
.Height = TextSize '0.5 'dim in declarations
.Update
found = True
End If
End With
Set elem = Nothing
Next elem
' If we didn't find text, notify user
If Not found Then
MsgBox "No text found in ModelSpace.", vbInformation
End If
End Sub
'done for now, jim kitts
Here is an alternative way by using ObjectDBX via axdb15.dll.
I runs really quick!
' Written by Jimmy B 2000-03-08
' Runs in AutoCAD 2000 with axdb15.dll
' Example of batch for changing text height on all drawings in a directory.
Private Sub setTextHeight()
Set objDbx = GetInterfaceObject("ObjectDBX.AxDbDocument")
Dim inDir As String
Dim elem As Object
Dim newHeight As Double
inDir = "c:\test"
newHeight = 3#
objDbx.Open WholeFile
For Each elem In objDbx.ModelSpace
With elem
If ((TypeName(elem) = "IAcadText") Or (TypeName(elem) = "IAcadMText")) Then
.Height = newHeight
End If
End With
Next elem
For Each elem In objDbx.PaperSpace
With elem
.Height = newHeight
End If
End With
Next elem
Set elem = Nothing
objDbx.SaveAs WholeFile
filenom = Dir$
Loop
End Sub
Best regards: Jimmy B
CAD coordinator at Emtunga International AB
www.emtunga.com
Nice example.
Something you might consider that will speed this up: do the update after
looping through all of the entities. As I understand it, update is the same
thing as a regen. If you do it once when you're all done processing then
that's all it takes; one regen of the entire drawing instead of regen each
object as you go along.
Just a suggestion.
Mike
"Ruth Mitchell or Jim Kitts" wrote in message
news:38C52501.429F75F8@nbnet.nb.ca...
> Sub SetCadBatch()
> End If
> Dim inDir As String
> 'check for a cancel
> If inDir = "" Then
> Exit Sub
> End If
> Dim tmp As String
> If temp = "" Then
> Exit Sub
> End If
> End If
> Exit Sub
> End If '
> 'do somthin next
> DoEvents
> DoEvents
> DoEvents
> filenom = Dir$
> Loop
> End Sub
> Dim elem As Object
> With elem
> .Update
> found = True
> End If
> End With
> Set elem = Nothing
> Next elem
> If Not found Then
> End If
> End Sub
My guess is that no update or regen is needed at all since the drawing is closed and saved.
Anyway: "The Update method updates the display of a single object only. The Regen
method regenerates the entire drawing and recomputes the screen coordi-nates
and view resolution for all objects. It also reindexes the drawing
database for optimum display and object selection performance."
www.emtunga.com
Michael Weaver skrev i diskussionsgruppsmeddelandet:8a5ou8$7vr11@adesknews2.autodesk.com...
> Nice example.
> Just a suggestion.
> Mike
> > Sub SetCadBatch()
> > End If
> > Dim inDir As String
> > 'check for a cancel
> > If inDir = "" Then
> > Exit Sub
> > End If
> > Dim tmp As String
> > If temp = "" Then
> > Exit Sub
> > End If
> > End If
> > Exit Sub
> > End If '
> > 'do somthin next
> > DoEvents
> > DoEvents
> > DoEvents
> > filenom = Dir$
> > Loop
> > End Sub
> > Dim elem As Object
> > With elem
> > .Update
> > found = True
> > End If
> > End With
> > Set elem = Nothing
> > Next elem
> > If Not found Then
> > End If
> > End Sub
>"Jimmy B" wrote in message
news:8a5s78$7tl24@adesknews2.autodesk.com...
closed and saved.
Good point.
Regen
coordi-nates
Then what does application.update do?
>www.emtunga.com
Michael Weaver
Charles Bettisworth & Co.
mweaver@bettisworth.com
Gee thanks. That is REAL fast. Mike Weaver tried to put me onto this before. I should
have listened a little more.
jim
