AxDb15.dll
AxDb15.dll
Message 1 of 10
AxDb15.dll
Is this the version I need for AutoCAD 2007?
I have two apps that require this and they don't work.  If so where do I
get it?  If not, what should version should the coding be replaced
with?
David M.
Gardner
Change the DOT to reply
Replies (9)
Message 2 of 10
AxDb15 is for R2000-2002 (ObjectDBX 1.0 Type Library)
AxDb16enu is for R2004-2006 (AutoCAD/ObjectDBX Common 16.0 Type Library)
AxDb17enu is for R2007 (AutoCAD/ObjectDBX Common 17.0 Type Library)
And you don't need to reference these if you Dimension your variable as an
Object rather than a AxDbDocument, at the cost of a small performance hit.
When you use GetInterfaceObject you must use:
Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument")
Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument.17")
depending on version.
Note that AxDb15 is the only one you need to check if it's registered. The
newer versions are registered during a normal install.
"David M. Gardner" wrote in message
news:5212161@discussion.autodesk.com...
Is this the version I need for AutoCAD 2007? I have two apps that require
this and they don't work. If so where do I get it? If not, what should
version should the coding be replaced with?
David M. Gardner
Message 3 of 10
Where or how can I get AxDb17enu.dll?
David M. Gardner
"Jeff Mishler" wrote in message
news:5212215@discussion.autodesk.com...
David M. Gardner
Message 4 of 10
If you have 2007 installed you have the odbx also.
Just set a reference to it in your project (AutoCAD/ObjectDBX Common 17.0
Type Library)
don't need to worry about the dll...acad takes care of that
hth
news:5257705@discussion.autodesk.com...
David M. Gardner
Message 5 of 10
FXVIPilot
Hi MB,
I found this (your) thread deals with exactly what I am trying to do, but I could not figure out from your instructions for fixing it, exactly what we need to modify. By "project" do you mean the lisp routine itself (i.e. not a project file within ACAD somewhere)? I have attached the propfind.lsp. Can you tell me what parts need changing to work in AutoCAD 2007? Thanks, William.
William
Message 6 of 10
Ed__Jobe
You're in the vba forum, not the lisp forum. Lisp doesn't deal with projects. You need to modify your lisp file.
Ed
How to post your code.
Message 7 of 10
I am having a similar problem in that I am trying to use the ObjectDBX with navisworks jetstream, and it says my ObjectDBX is only compatible with AutoCAD 2004/2005/2006.
In my common files I have axdb16.dll, axdb16enu.tlb, and axdb17enu.tlb.
What lisp file do I need to modify in order for Navisworks to use the R17 version in regards to AutoCAD documents?
Message 8 of 10
dgorsman
NavisWorks Roamer doesn't use LISP.
For AutoCAD 2007, I believe you need to download an object enabler.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 9 of 10
The error happens only when I am loading an AutoCAD file that was saved in the 2007 format. When I save it down to 2006 or 2004 then it loads just fine.
Message 10 of 10
I have this same issue and the same results have you had any luck getting rid of this??
