Autocad VBA and Microsoft Visual Source Safe
Message 1 of 8
Hi! It's possible to integrate the autocad VBA modules with Microsoft Visual Source Safe for handling the project modules, sharing some modules between different Autocad projects? Thanx in advance! Davids
Replies (7)
Message 2 of 8
In VS, modules are separate files. In vba, they are compiled into a dvb, so...no. Unless you export everything in your dvb. When I want to share modules in acad vba, I just created a Toolbox.dvb and reference that dvb from the other dvb's. The only other caveat, is that, for Intellisense to work, you need to qualify the whole object heirarchy. Whereas, when the function was in the same project, you only had to specify the function's name. Now, when the function is outside the project in another dvb, you need to specify a fully qualified name, fqn, using the syntax, Project.Module.Procedure. -- ---- Ed ---- "Davids" wrote in message news:40e3c309$1_3@newsprd01... Hi! It's possible to integrate the autocad VBA modules with Microsoft Visual Source Safe for handling the project modules, sharing some modules between different Autocad projects? Thanx in advance! Davids
Message 3 of 8
Thanx Ed... This may be a small solution, but you don't may evaluate the difference between two version of the same module... In the add-in manager i see the VSS add-in link but after her start the login dialog don't see the VSS database... There's a additional component to install to work? Also Access is a unique file, but the VSS add-in split this file in more files and these files are added to VSS... Autocad may work similary? Davids ____________________________________________________________________________ ___ "Ed Jobe" wrote in message news:40e43047$1_1@newsprd01... In VS, modules are separate files. In vba, they are compiled into a dvb, so...no. Unless you export everything in your dvb. When I want to share modules in acad vba, I just created a Toolbox.dvb and reference that dvb from the other dvb's. The only other caveat, is that, for Intellisense to work, you need to qualify the whole object heirarchy. Whereas, when the function was in the same project, you only had to specify the function's name. Now, when the function is outside the project in another dvb, you need to specify a fully qualified name, fqn, using the syntax, Project.Module.Procedure. -- ---- Ed ----
Message 4 of 8
>>two version of the same module... The point is, using this method, I don't have two versions of the same module. All dvb's access the common module for what they need, instead of duplicating it over and over. Its like having a common dll. If you still MUST use vss, export the modules from the dvb (they will get saved as bas and cls files) and then bring them into vss for comparison. I havn't tried it though, but I believe that would be your only way. -- ---- Ed ---- "Davids" wrote in message news:40e5314b$1_1@newsprd01... Thanx Ed... This may be a small solution, but you don't may evaluate the difference between two version of the same module... In the add-in manager i see the VSS add-in link but after her start the login dialog don't see the VSS database... There's a additional component to install to work? Also Access is a unique file, but the VSS add-in split this file in more files and these files are added to VSS... Autocad may work similary? Davids ____________________________________________________________________________ ___ "Ed Jobe" wrote in message news:40e43047$1_1@newsprd01... In VS, modules are separate files. In vba, they are compiled into a dvb, so...no. Unless you export everything in your dvb. When I want to share modules in acad vba, I just created a Toolbox.dvb and reference that dvb from the other dvb's. The only other caveat, is that, for Intellisense to work, you need to qualify the whole object heirarchy. Whereas, when the function was in the same project, you only had to specify the function's name. Now, when the function is outside the project in another dvb, you need to specify a fully qualified name, fqn, using the syntax, Project.Module.Procedure. -- ---- Ed ----
Message 5 of 8
Ance I thought to proceed in this way... I hoped was an other way. Thanks for your help Ed! Davids "Ed Jobe" wrote in message news:40e577bb_2@newsprd01... >>two version of the same module... The point is, using this method, I don't have two versions of the same module. All dvb's access the common module for what they need, instead of duplicating it over and over. Its like having a common dll. If you still MUST use vss, export the modules from the dvb (they will get saved as bas and cls files) and then bring them into vss for comparison. I havn't tried it though, but I believe that would be your only way.
Message 6 of 8
In order to utilize VSS with my VBA (DVB) project I converted everything to a DLL and then just used a VBA stub. The benefits of using VSS with my code made it well worth it. Best regards, Dale "Davids" wrote in message news:40e57da7_3@newsprd01... > Ance I thought to proceed in this way... I hoped was an other way. Thanks > for your help Ed! > Davids > > "Ed Jobe" wrote in message > news:40e577bb_2@newsprd01... > >>two version of the same module... > The point is, using this method, I don't have two versions of the same > module. All dvb's access the common module for what they need, instead of > duplicating it over and over. Its like having a common dll. > > If you still MUST use vss, export the modules from the dvb (they will get > saved as bas and cls files) and then bring them into vss for comparison. I > havn't tried it though, but I believe that would be your only way. > >
Message 7 of 8
Thenk you for the suggestion, but I do not know like applying it. You could kindly write the instructions on like making to me? Thanks! Davids __________________________________________________ "Dale Levesque" wrote in message news:40eb0a22_3@newsprd01... > In order to utilize VSS with my VBA (DVB) project I converted everything to > a DLL and then just used a VBA stub. The benefits of using VSS with my code > made it well worth it. > > Best regards, > > Dale >
Message 8 of 8
I use VB 6.0 so, 1.) Start a new ActiveX DLL Project. 2.) Export your VBA project to individual BAS, FRM files etc. 3.) Add these files to the DLL. 4.) Compile the DLL. 5.) Add the DLL reference to your DVB project. 6.) Call the DLL routines from your DVB file using the following format: DLL_Name.Routine_Name HTH, Dale "Davids" wrote in message news:40eba30f$1_1@newsprd01... > Thenk you for the suggestion, but I do not know like applying it. > You could kindly write the instructions on like making to me? Thanks! > Davids > __________________________________________________ > "Dale Levesque" wrote in message > news:40eb0a22_3@newsprd01... > > In order to utilize VSS with my VBA (DVB) project I converted everything > to > > a DLL and then just used a VBA stub. The benefits of using VSS with my > code > > made it well worth it. > > > > Best regards, > > > > Dale > > > >
