AutoCAD Table modify cell values from Excel VBA controlling code
kevin_hay
kevin_hay
Hi everyone.
I am currently controlling AutoCAD via the send command method from Excel. My code opens up a new instance of AutoCAD, opens up a specific template and then runs a series of commands through this method to construct a completed drawing. (this part is working well)
My challenge is to then modify cell values within an existing AutoCAD Table. I had thought I could use the tabledit command, pass the coordinates to select the cell and then drop text into the mtext editor to populate the change, however when pushing the text into the mtext editor it does not accept it. I also tried the sendkeys method and the data only appears once the text editor for the cell is closed.
Can anyone recommend a way of accessing the set cell value method via Excel so I can access the cell values directly? I'd rather achieve this than revert back to editing the table directly in autocad via visual lisp.
In summary, I have a range of cells in Excel with calculated data from structural calculations that I require to dump into cell values within an existing AutoCAD Table object and I'd like to do this by pushing the data from excel rather than pulling the data into AutoCAD.
Kev.
Ed__Jobe
You need to use vba code to directly edit the table cell contents, not SendCommand. This post should get you started.
Ed
How to post your code.
kevin_hay
Thanks Ed.
I'll take a look and see how I get on.
Appreciate the input.
Cheers,
Kev.
