Autocad LT DDE
Autocad LT DDE
Message 1 of 1
Autocad LT DDE
Hi Autodesk,
I have used some VB6 code on different versions of Autocad LT for years, sending several blocks from a VB6 project to Autocad LT, using DDE. The latest working version is Autocad LT 2010. Everything worked well with that version.
Now with Autocad LT 2015 and 2016, it no longer works. I updated the code to use the new drawing version and the new exe file. It will only send one block to the drawing. Is there a change to Autocad LT and DDE, that now prevents this from working?
Thanks for your help!
Replies (0)
