Autocad 2022 VBA Automation error using CreateObject("VL.Application.16")
A.vanNieuwenhuize
A.vanNieuwenhuize
I have used  "CreateObject("VL.Application.16") " upto autocad 2018i to
get lisp variables into VBA macro's.
example:
Set objVisualLisp = CreateObject("VL.Application.16")
With objVisualLisp.ActiveDocument.Functions
Set objSymbol = .item("read").funcall("H:ExcelShareName")
GetPathFormSymbol = .item("eval").funcall(objSymbol)
End With
While using Autocad 2022 the next  Automation error is fired
run-time error '-2147220999 (800401f9)':
Automation error
Error in the DLL
Who can help me with this problem
Ad ios
Ed__Jobe
I'm running 2021 and the class name is still "VL.Application.16". Which line is giving the error? If its the CreateObject line, have you tried repairing AutoCAD?
Just to be certain, you are running this code inside AutoCAD?
Ed
How to post your code.
A.vanNieuwenhuize
Ed thanks for your fast reply.
I am talking about Autcad 2022 and not 2021.
The line CreateObject("VL.Application.16") is firing the error message.
Ad ios
A.vanNieuwenhuize
Ed__Jobe
It's still the same for 2022. You didn't answer if you tried to repair the AutoCAD installation.
Ed
norman.yuan
@A.vanNieuwenhuize ,
I just got a 2022 AutoCAD vertical (Plant3D) installed,  did test and found interesting change on this:
This line of code:
works for older version of AutoCAD (I only has 2020 and 2021, no anything older accessible for now). But indeed it raises exception with Acad2022.
While this line of code:
Set objVisualLisp = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
works on all versions of AutoCAD (again, I only have Acad2020 and up).
Whatever changes, in my view, as AutoCAD programmer, GetInterfaceObject() should be the right approach to instantiate an object that is not a direct part of AutoCAD COM Model, but runs inside AutoCAD process and interacts with AutoCAD objects, whereas CreateObject() is used to instantiate object that runs outside of AutoCAD process. So, whatever Acad2022 does that causes this change/error, it is technically right thing to do, but it unfortunately breaks some existing code, as yours.
Norman Yuan
Drive CAD With Code
