AutoCAD 2011 Batch Convert Field attribute to text attribute in blocks using VBA
I've got hundreds of files to convert.
In VBA, how can I batch convert field attributes in blocks to text attributes while retaining the blocks?  Is there a simple way to univerally convert them all at onceusing VBA?  The plotted values for the fields must be retained, too.
Explode will not retain the value of the field.
Burst will not work as it explodes the blocks as well.
You can right-click on the field and slelct "Convert to text" from the RCM.  So I know that the process exists within CAD, just need to batch the process for a quantity of DWGs at a time - in VBA.
Hallex
Try this trick on single attribute
Hint:
Sub Demo()
Dim att As AcadAttributeReference
Dim oEnt As Object
Dim pickPt As Variant, tmx As Variant, ctx As Variant
ThisDrawing.Utility.GetSubEntity oEnt, pickPt, tmx, ctx, vbCrLf & "Select attribute with field >>"
If TypeOf oEnt Is AcadAttributeReference Then
Set att = oEnt
Dim attvalue As String
attvalue = att.TextString
att.TextString = ""
att.TextString = attvalue
Else
MsgBox "Selected object is not an attributee reference: " & oEnt.ObjectName
Exit Sub
End If
End Sub
