AutoCAD 2002 VBA & MS Access 97: Run-time error'3706'- Provider cannot be
11:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
The following VBA program codes ran OK in the VBA of AutoCAD R14.01 before, but not in the VBA of AutoCAD 2002 that generated "Run-time error'3706'- Provider cannot be found":
Public Sub CreateCircles()
' Connect to the database using ADO and read
' coordinate data out of it to produce the
' drawing
Dim conServer As ADODB.Connection
Dim rstCircle As ADODB.Recordset
Dim rstMetaData As ADODB.Recordset
Dim cir As AcadCircle
Dim ptCenter(0 To 2) As Double
Dim vecNormal(0 To 2) As Double
' Connect to the data source
Set conServer = New Connection
With conServer
.ConnectionString = "Provider=Microsoft.Jet.OLEDB4.0;" _
& "Data Source=C:\AppDev\VBA Solu\Chapter4.mdb"
' We don't need to be able to do anything but read data
.Mode = adModeRead
.Open
End With
' Now retrieve the records
Set rstMetaData = New ADODB.Recordset
With rstMetaData
.Source = "SELECT * FROM tblCircle"
.ActiveConnection = conServer
.Open
' Create a circle object for each record
Do Until .EOF
' Find the center and make the circle
ptCenter(0) = !CenterX
ptCenter(1) = !CenterY
ptCenter(2) = !CenterZ
Set cir = ThisDrawing.ModelSpace. _
AddCircle(ptCenter, !Radius)
' Rotate the circle to match the
' supplied normal vector
vecNormal(0) = !NormalX
vecNormal(1) = !NormalY
vecNormal(2) = !NormalZ
cir.Normal = vecNormal
' Set the color
cir.Color = !Color
' And draw it
cir.Update
.MoveNext
Loop
.Close
End With
' Free the connection to the server
conServer.Close
Set cir = Nothing
End Sub
I have tried to set up the OLE DB configuration in my AutoCAD 2002 References without success: (1) If I have "Microsoft OLEDB Service Component 1.0 Type Library" and "OLE Automation" checked in the References of the Tools menu, I got "Run-time error '3706' all the times. (2) If I have "Microsoft OLE DB Simple Provider 1.5 Library" checked, then I got "Microsoft Visual Basic Error in loading DLL". I am a new VBA user and do not know what is wrong in the AutoCAD 2002 VBA programming that used ADO or OLE DB to get MS Access 97 data - The MS Access 97 is on the Microsoft 2000 built on NT Technology. Please help and tell me how to solve this problem.
Thanks in advance,
Scott Chang
' drawing
With conServer
.Mode = adModeRead
.Open
End With
With rstMetaData
.Open
Do Until .EOF
' Set the color
cir.Color = !Color
' And draw it
cir.Update
.MoveNext
Loop
.Close
End With
conServer.Close
Set cir = Nothing
End Sub
Thanks in advance,
Scott Chang
