Autocad 2000 VBA Macro to Autocad 2009
Would it be possible to migrate my Autocad 2000 VBA customization to Autocad 2009 VBA, what it does in Autocad 2000 when it loads, it creates a toolbar which has customized command. When i try it to Autocad 2009 the toolbar no longer loads.
Appreciate any help.
Mayller
Can you post your code here?
Hi Steven,
Did some googling and found a few good resolution, btw i have a new problem now. I already able to load the toolbar and one of the button is producing Activex component cant create object here is the script from where it occured:
Private Sub TabBlocks_Change()
Dim Pic As Picture
Dim sItemStr As String
Dim intIndex As Integer
Dim ItmList As ListItem
Dim sIniAppName As String
Dim sItemX As String, sItemY As String
Dim intlen As Integer, intItmCount As Integer
Dim sItemName As String, sItemBitmap As String, sItemCommand As String
Dim intItemX As Integer, intItemY As Integer, intImageIndex As Integer
If bInitialising Then Exit Sub
'Note that TabBlocks.Tabs is a zero base array while our ini file starts with 1
sIniAppName = "Tab" & TabBlocks.SelectedItem.Index + 1
intItmCount = GetPrivateProfileInt(sIniAppName, "ItemCount", 0, msIniFileName)
ListViewBlocks.ListItems.Clear
Set ListViewBlocks.Icons = Nothing
Set mImageListBlocks = Nothing 'Unload all the previous images explicitly
Set mImageListBlocks = New ImageList
For intIndex = 1 To intItmCount
sItemStr = GetProfileString(msIniFileName, sIniAppName, "Item" & intIndex, "Error")
If sItemStr <> "Error" Then
sItemName = GetToken(sItemStr, ",")
sItemBitmap = GetToken(sItemStr, ",")
sItemY = GetToken(sItemStr, ",")
sItemX = GetToken(sItemStr, ",")
sItemCommand = sItemStr
On Error Resume Next
Set Pic = Nothing
Set Pic = LoadPicture(msBmpDir & sItemBitmap)
On Error GoTo 0
If Not Pic Is Nothing Then
intImageIndex = mImageListBlocks.ListImages.Add(, , Pic).Index
If intImageIndex = 1 Then ListViewBlocks.Icons = mImageListBlocks
With ListViewBlocks.ListItems.Add(, , " ", intImageIndex)
.Left = (CInt(sItemX) - 1) * 35
.top = (CInt(sItemY) - 1) * 35
.tag = sItemCommand
End With
Next
ListViewBlocks.Refresh
End Sub
 Somehow the error occurs in:
What could be wrong.
Mayller
What is the exact error you are getting?
This was the exact error:
Runtime Error 429 - ActiveX Component Cannot Create Object.
Unfortunately, I can't debug this with just the code you have posted. Perhaps somebody with more experience can help here?
Have you googled for "vba imagelist runtime error 429"? There are different reasons listed for this error happening and I don't know which would apply to your situation.
