Attribute vales to text
Is there a quick method or a routine that can convert an attributed block to lines and text. If I explode the block my attributed text turns into the tagstring text not the attributed value?
Not VBA, but a lisp, "tag2txt.lsp".... look under "Free Stuff" at www.dotsoft.com, courtesy Terry Dotson. HTH, Jeff "chaseling" wrote in message news:[email protected]... > Is there a quick method or a routine that can convert an attributed block to lines and text. If I explode the block my attributed text turns into the tagstring text not the attributed value?
Express Tools - BURST will do the trick. -- Matt W There are 3 kinds of people: Those who can count, and those who can't. "Jeff Mishler" wrote in message news:403d9cc6$1_1@newsprd01... > Not VBA, but a lisp, "tag2txt.lsp".... look under "Free Stuff" at > www.dotsoft.com, courtesy Terry Dotson. > > HTH, > Jeff > > "chaseling" wrote in message > news:[email protected]... > > Is there a quick method or a routine that can convert an attributed block > to lines and text. If I explode the block my attributed text turns into the > tagstring text not the attributed value? > >
Express tools has a "Burst" command that does this. Under the express tools menu "Explode attributes to text" chaseling wrote: > Is there a quick method or a routine that can convert an attributed block to lines and text. If I explode the block my attributed text turns into the tagstring text not the attributed value?
