Arrows at the end of the arcs
Hello all
How to draw or insert an arrow at the two ends of the arc.
Similar to dimangular having arrows at the two ends of the arc.
I am drawing an arc and having the arrow as a block.Now i do not know the
angle to which i should rotate the block so that it matches with the start and end points.
I think there could be some simple solution for this.
Sri
Hi Sri,
If you have an arc part of its properties include the StartAngle and
EndAngle.
You can use those values to set the angles of your inserted arrows.
You can also use the StartPoint and EndPoint to locate the arrow
Laurie Comerford
www.cadapps.com.au
wrote in message news:4860284@discussion.autodesk.com...
Hello all
and end points.
Sri
Hi Laurie Comerford
Thanks for your input, but i had tried with it and it is not solving the problem.
thanks
Sri
Yes it does with some angle (90) addition and deletion.
thanks
Sri
