Angle between two points
Hi all,
Is it possible to find the angle between two user selected points? If so,
can someone point me in the right direction. I have no idea where to begin!
TIA,
Rob
You can not compute an angle between 2 points. Can you clarify what you want
to do ?
Luc Morrissette,
Flairbase inc.
"Rob Outman" wrote in message
news:FD0107F1FDBD06F9676594F5E326E170@in.WebX.maYIadrTaRb...
> Hi all,
begin!
> TIA,
> Rob
Check out the AngleFromXAxis method of the AcadUtility class.
http://www.acadx.com
Good judgement comes from experience.
Experience comes from bad judgement.
> Hi all,
begin!
> TIA,
> Rob
Hi Rob
I'm not sure what you like to do, but maybe this function helps you:
Public Function UserAngle(FstPnt As Variant, NxtPnt As Variant) As Double
Dim TmpObj As AcadLine
Set TmpObj = ThisDrawing.ModelSpace.AddLine(FstPnt, NxtPnt)
With TmpObj
UserAngle = TmpObj.Angle
TmpObj.Delete
End With
End Function
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
Rob Outman schrieb:
> Hi all,
> TIA,
> Rob
Hi Rob,
I'm just learning this stuff myself, but try something like this:
pangle = ThisDrawing.Utility.AngleFromXAxis(sp, ep)
Of course, sp is the starting point or point one and ep is the ending point
or the other point.
I think this is what Mr. Oquendo was referring to earlier in the thread.
Sal
> Hi all,
begin!
> TIA,
> Rob
Thanx all,
I have used the method described by Jurg for the moment, but I am going to
do some more research into the AngleFromXAxis method mentioned by Frank.
Thanx again,
Rob
"Sal Brusco" wrote in message
news:E8442744501C2C23BB0F05A57140BFC4@in.WebX.maYIadrTaRb...
> Hi Rob,
point
> or the other point.
> Sal
> > Hi all,
so,
> begin!
> > TIA,
> > Rob
