angle between lines
angle between lines
angle between lines
I am trying to find the angle between 2 lines. If I could pick one line,
then the other, and have it return the angle between the two. (They share
an endpoint). Any help would be appreciated.
I am writing a door insertion utility.
Robert B. Brown
Lead Visualization Specialist
Autometric Inc.
http://www.autometric.com
This is untested (I'm typing it into this message for the first time), but
should give you a start.
I'll assume that you have references to the two line objects already, that
you want the acute angle, and that the lines are 2-D.
Public Function AngleBetweenLines (byref objLine1 As AcadLine, byref
objLine2 As AcadLine) As Single
Dim sngAngle As Single
sngAngle = Abs(objLine1.Angle - objLine2.Angle)
If sngAngle > 180 then
sngAngle = 360 - sngAngle
End If
AngleBetweenLines = sngAngle
End Function
--Bill
Robert Brown wrote in message
<8F0C8A534rbrownautometriccom@167.216.240.240>...
>Robert B. Brown
>Autometric Inc.
Bil,,
I think that this will work, but I am having some bizarre units problems.
What I really want to do is determine the angle based on 3 points, but this
method will probably work, I didn't think about the simpl solution that you
presented here.
Rob
bdaly@millerlegg.com (Bill Daly) wrote in :
> End If
>End Function
> --Bill
>>Robert B. Brown
>>Autometric Inc.
Robert B. Brown
Autometric Inc.
