AeccAlignment referenced Library
sergiopedroza
sergiopedroza
Hi all,
I'm new here and my English is not the best, so sorry for any mistakes. I am trying to list all the curves of an alignment (circular and transition) using VBA and a compilation error is appearing: the user defined type has not been defined. This error appears in the "Dim oAlign As AeccAlignment" command.  I know I need to select the reference library in VBA but I don't know which one. Could someone give me a hand?
Ed__Jobe
It should be AeccXLandLib. BTW, you can figure it out if you reference it and then open the Object Browser and see what objects the library contains.
Ed
How to post your code.
sergiopedroza
thanks Ed.Jobe. it worked
