ADO Connection Create File Excel
Aubelec
Aubelec
Hello.
How créate a ADO connection for create un file .XLS ?
I know how read a existing file XLS.
SQL command : SELEC * ... but if i use CREATE TABLE...
the vba say : the file open only in read.
dim strfile as string
Dim cnn As New ADODB.Connection
dim rs as new ADODB.Recordset
strfile=c:\mynewfile.xls
cnn.ConnectionString = "Driver={Microsoft Excel Driver (*.xls)};DBQ=" & strfile"
cnn.open
rs.open "Create table ..."
How create a file .XLS without the excel application ?
I doubt that you can create an Excel file without the Excel application. I
think that your code would not create a file if it worked; it would create
a named range.
Excel is not really a database, and there are restrictions on what ADO can
do with an Excel file. See
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q257819 .
jrf
Autodesk Discussion Group Facilitator
Please do not email questions unless you wish to hire my services
On Thu, 15 Jun 2006 10:02:34 +0000, Aubelec wrote:
> Hello.
strfile"
> cnn.open
Aubelec
Thx for the link.
Ithink i have to use application excel for create the file and after close file and modifing with ado.
it is much easy for use a bas with ado.
and i have a little prob for close excel.exe. 😛
Sounds more like you should be using a database application to create a
database instead.
Joe
wrote in message news:5207650@discussion.autodesk.com...
Thx for the link.
You need ADOX to do it.
This is how you would create the excel file
Dim cat As ADOX.Catalog
Dim tbl As ADOX.Table
Dim col As ADOX.Column
Set cat = New ADOX.Catalog
cat.ActiveConnection = "Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source="
& myfile & ";Extended Properties=Excel 8.0"
Set tbl = New ADOX.Table
tbl.Name = "Sample"
'do this for each column in the table
Set col = New ADOX.Column
With col
.Name = "myTipe"
.Type = adVarWChar
.DefinedSize = 80
End With
tbl.Columns.Append col
You can then open the file with ADO to write your info
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
wrote in message news:5207082@discussion.autodesk.com...
Hello.
strfile"
cnn.open
Aubelec
Hello the soluce for you. from Help file of Acces (Ms Office) :
Sub Main()
On Error GoTo CreateAutoIncrColumnError
Dim cat As New ADOX.Catalog
Dim tbl As New ADOX.Table
cnn.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source=" & "C:\Test.XLS" & ";Extended Properties=Excel 8.0" Set cat.ActiveConnection = cnn
With tbl
.Name = "MyContacts"
Set .ParentCatalog = cat
' Create fields and append them to the new Table object.
.Columns.Append "ContactId", adInteger
' Make the ContactId column and auto incrementing column
.Columns("ContactId").Properties("AutoIncrement") = True
.Columns.Append "CustomerID", adVarWChar
.Columns.Append "FirstName", adVarWChar
.Columns.Append "LastName", adVarWChar
.Columns.Append "Phone", adVarWChar, 20
.Columns.Append "Notes", adLongVarWChar
End With
cat.Tables.Append tbl
'Clean up
cnn.Close
Set cat = Nothing
Set tbl = Nothing
Set cnn = Nothing
Exit Sub
CreateAutoIncrColumnError:
Set cat = Nothing
Set tbl = Nothing
If Not cnn Is Nothing Then
If cnn.State = adStateOpen Then cnn.Close
End If
Set cnn = Nothing
If Err 0 Then
MsgBox Err.Source & "-->" & Err.Description, , "Error"
End If
End Sub
100% working. (just need a corret file/path.) +
Add Ref : (Menu Tools - Réf)
Microsoft ADO +
Microsoft ADO Ext
