Active space for an Autocad Object
NGVBA
Message 1 of 9
NGVBA
Hi All,
I am working on a project with Autocad VBA.
My requirement is to gather the "ActiveSpace" of an object.
What I am doing is ......... based on a certain criteria (Using Filters) I am making a selection set and then transferring the entity info (Which are in selection set) to excel e.g. handle, layer etc.
I want to also know the active space i.e. either "Model" or "Paper".
At the moment I tried to use oSset.items(i).document.ActiveSpace but it only gives me the active space of the document and not where the object resides.
Any help would be much appreciated.
Replies (8)
Message 2 of 9
Ed__Jobe
For entities, the OwnerID property will be a pointer to the container object, which is either the modelspace block, the paperspace block or the block table.
Ed
How to post your code.
Message 3 of 9
norman.yuan
Well, since you use SelectionSet with filter to select entities, you can certainly add filter to filter entities in ModelSpace or PaperSpace, or entities on specific layout:
Filter for ModelSpace/PaperSpace
Group code: 67
Value: 0 (or omitted) - ModelSpace; 1 - PaperSpace
Filter to Layout Name
Group code: 410
Value: a string value of Layout name, such as "Layout1"
Norman Yuan
Drive CAD With Code
Message 4 of 9
NGVBA
Thanks for the quick reply.
I used oSset.items(i).document.Ownerid but strange thing happened, when I run the Subroutine by pressing either F5 or F8, excel instance crashes.
I tried this many times but this does not work
Strangely if I use oSset.items(i).document.ActiveSpace it executes (but it is not what I want).
Any clues ??
Thanks in advance.
Message 5 of 9
NGVBA
Thanks Norman.
On this forum I have been benefitted many a times by your posts.
You are right I can filter for the space but I want the Entities both from paper AND model space along with the entity "Residing" space to be captured through iteration of the selection set entities.
Jobe has suggested to use "OwnerId" but I can't execute that command, Excel crashes when I run it even if I try to press F8 for the subroutine.
Any clues ??
Message 6 of 9
norman.yuan
You need to use AcadEntity.OwnerId, not AcadDocument.OwnerId (e.g. oSset.Item(i).OwnerId) to trace back to the space/layout the entity belongs to. Something like:
Private Function GetLayoutName(ent As AcadEntity) As String
  '' If the entity belongs to one of the layouts
  Dim lay As AcadLayout
  For Each lay in ThisDrawing.Layouts
    If lay.Block.ObjectId = ent.OwnerId Then
      GetLayoutName=lay.Name
      Exit Function
  Next
  '' Then it must be from ModelSpace
  GetLayoutName="Model"
End Function
To use it:
Dim ent As AcadEntity
Dim spaceName As String
For Each ent in oSset
  spaceName=GetLayoutName(ent)
  MsgBox "This entity is in " & spaceName
Next
I see you mentioned that your code is actually run in Excel. So, to be warned: if you have large SelectionSet, the code would run fairly slow in comparison to running in AutoCAD VBA.
Norman Yuan
Drive CAD With Code
Message 7 of 9
NGVBA
Thanks for the code Norman.
I understand that this shall work perfectly but my code is acting weird......
I put the function GetLayoutName(ent As AcadEntity) in the code module and when the subroutine code calls the function, my excel crashes.
As I explained earlier as soon as I put "OwnerId" any where  in the code, it crashes the excel.
Have you experience anything like this before and what could be the remedy for it?
Message 8 of 9
NGVBA
I discovered while browsing through the past forum discussions and found the below one :
https://forums.autodesk.com/t5/vba/automation-error-ownerid-in-excel/td-p/8018188
This is really good and I could achieve the desired result through late binding.
Thanks a lot for your support.
Message 9 of 9
norman.yuan
The crash you get is likely that your Excel is 32-bit (thus its VBA also 32-bit), while ObjectId  (e.g. OwnerId property) in AutoCAD COM API is 64-bit long (longPtr type, which is not available in 32-bit VBA), therefore the crash.
So, if you have to do it from Excel VBA side, you have to avoid to touch the data type that is not available in 32-bit VBA, which is not possible in this case (because you need to access OwnerId to decide the layout an entity belongs to). I suspect that the late binding would not help in this case. SO, you either use 64-bit Excel, or doing the work on AutoCAD side. IMO, automating AutoCAD from external app (Excel, in your case) is hardly a good approach. If the work involves quite some AutoCAD operations, it should be done from AutoCAD side (e.g. AutoCAD VBA, or lisp, or .NET plugin...).
Norman Yuan
Drive CAD With Code
