Actions after loading .DVB file
Hi there,
Is it possible to do actions directly after loading the DVB file by command appload in the autocad command bar?
For example, creating a menu in the menu bar with the available procedures in the .DVB?
Alfred.NESWADBA
does that help
Private pInitFinished As Boolean
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
   If Not pInitFinished Then
      pInitFinished = True
      Call MsgBox("Running initialization")
      'do what have to be done
   End If
End Sub
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Well it works, it send the msgbox after loading the file directly,Could yuo kindly give me more details about it?
Alfred.NESWADBA
wasn't that what you where looking for? Just replace the "msgbox"-statement with your code for loading a menu or do some initialization, it's then called automatically when this DVB is loaded.
That was the question I thought ... or what did I understand wrong?
- alfred -
Alfred NESWADBA
