Access database and AutoCAD 2000
Message 1 of 11
Replies (10)
Message 2 of 11
Whats the easiset way for Access '97 and AutoCAD 2000 to interact as far as Extracting information out of AutoCAD drawings and having it show up in Access.
I know how to control ACAD in VB/VBA using attributes and so forth. But is there an easier way like ODBC or something.
Message 3 of 11
Douglas,
You can use the Data Access Object (DAO) in Windows by simply referencing it
into your VBA project. ([Tools/References] then select "Microsoft DAO 3.x
Oject Library".)
This will allow you to use either an ODBC or Jet Database Engine connection
to insert/update/select data from the MDB file directly. You may have to
learn a little about the DAO, but that probably would be time well spent if
you plan to work with databases in the future--and a ton of information is
available on it.
Here is some code that uses the Jet Database Engine. I pulled it from an old
example I wrote, and it probably will not work in it's current state.
(paths, filenames etc.) but it shows how to open you MDB file using the DAO.
Option Explicit
Public gws As Workspace
Public gdb As Database
Public gstrDBName As String
Public Function OpenPartsDatabase(strDatabasePath As String) As Boolean
OpenPartsDatabase = False
Dim strPswd As String
On Error GoTo UnknownError
If IsFileFound(strDatabasePath) Then
' Sets password
strPswd = ""
' sets and opens the global workspace
Set gws = CreateWorkspace("PartsWorkspace", "Admin", "", dbUseJet)
' sets and opens the global database
Set gdb = gws.OpenDatabase(strDatabasePath, False, False, ";pwd=" &
strPswd)
Else
GoTo UnknownError
End If
OpenPartsDatabase = True
UnknownError:
End Function
Public Function IsFileFound(strFullFileName As String) As Boolean
IsFileFound = False
On Error GoTo TheFileWasntFound
If strFullFileName = "" Then
Exit Function
End If
If Dir(strFullFileName, vbNormal) <> "" Then
IsFileFound = True
Exit Function
End If
TheFileWasntFound:
End Function
Function drawMyCube()
ThisDrawing.Regen False
If OpenPartsDatabase("C:\DrawBox.mdb") Then
frmBox.GetPartsList
frmBox.Show
Else
MsgBox "The database coudn't be found.", vbOKOnly, "Error opening
database"
End If
End Function
Sub Test()
drawMyCube
End Sub
This code retrieves data from the MDB file.
Function GetPartsList() As Boolean
GetPartsList = False
Dim ors As Recordset
Dim strSQL As String
strSQL = "SELECT DISTINCT PartNumber, Description "
strSQL = strSQL & "FROM Parts "
strSQL = strSQL & "ORDER BY PartNumber "
Set ors = gdb.OpenRecordset(strSQL, dbOpenSnapshot)
If ors.RecordCount Then
While Not ors.EOF
lstParts.AddItem (ors!PartNumber)
lstParts.List(lstParts.ListCount - 1, 0) = ors!PartNumber
lstParts.List(lstParts.ListCount - 1, 1) = ors!Description
ors.MoveNext
Wend
GetPartsList = True
lstParts.ListIndex = 0
End If
ors.Close
UnknownError:
End Function
This code updates (puts) data in the MDB file. (You would probably use an
"INSERT" query here.)
Function UpdateData() As Boolean
UpdateData = False
strSQL = "UPDATE Parts "
strSQL = strSQL & "SET Length = " & txtLength & ", "
strSQL = strSQL & "Width = " & txtWidth & ", "
strSQL = strSQL & "Height = " & txtHeight & " "
strSQL = strSQL & "WHERE PartNumber = """ &
lstParts.List(lstParts.ListIndex, 0) & """"
gdb.Execute strSQL
UpdateData = True
UnknownError:
End Function
Notice that I use ANSI SQL for all my read/write opperations into the MDB
file. This will allow you to easily move this code to use a ODBC record
source if you ever want to. (A good habit.)
All you have to do is change this:
To this:
Set gws = CreateWorkspace("PartsWorkspace", "Admin", "", dbUseODBC)
Then you might have to change the connection string (as the following line
would not be valid for a SQL Server or Oracle connection:
strPswd)
I hope this helps!
Until later,
Jeremy McMahan
Premier Product Support
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
"DouglasPoston" wrote in message
news:[email protected]...
Access.
Message 4 of 11
ActiveX Data Objects is probably the way to go in your
situation. See "AutoCAD Database Connectivity", Scott
McFarlane, ISBN 0-7668-1640-0.
jrf
Member of the Autodesk Discussion Forum Moderator Program
Message 5 of 11
Hi Jemery,
We have a similar query that does not work neither in 97 nor Access 2000.
Would you have time to try this:
strSQL = strSQL & "WHERE PartNumber IN "
strSQL = strSQL & "(SELECT PartNumber FROM Parts WHERE PartNumber
BETWEEN 50 AND 100)"
I known the sub-query in this sample make no sense,
but if you have column PartNum in table NewParts it will.
We could not get the result even between 9 and 10 for 5 minutes.
(The Jet engine is a funny name.)
Message 6 of 11
Quan,
First of all, it will be hard to test without your MDB file... but just
looking at the SQL I have a couple of comments.
I presume that the line that reads:
"strSQL = strSQL & "(SELECT PartNumber FROM Parts WHERE PartNumber BETWEEN
50 AND 100)"
Is being executed as:
strSQL = strSQL & "(SELECT PartNum FROM NewParts WHERE PartNum BETWEEN 50
AND 100)"
Also, do you have the PartNumber field indexed in both tables? This will
improve performance dramatically.
Your SQL seems sound to me, but I always avoid using "IN" queries whenever
possible. They are almost always slower then direct comparisons.
(How big is the MDB? Is the MDB on a network share or local? How many
records are in the tables? Have you compacted the MDB lately? etc.)
Until later,
Jeremy McMahan
"Quan Kieu" wrote in message
> Hi Jemery,
> Thanks
Message 7 of 11
You wrote:
You can use the Data Access Object (DAO) in Windows by simply referencing it into your VBA project. ([Tools/References] then select "Microsoft DAO 3.x Oject Library".)
There is no "References" under Tools In AutoCAD 2000. I know its in Access or Visual Basic.
My question is what can be done on the AutoCAD side to link to a .MDB.
Or do I have to use the this code
Dim objAcadApp As AcadApplication
Dim ThisDrawing As AcadDocument
Set objAcadApp = CreateObject("AutoCAD.Application.15")
objAcadApp.Visible = True
Set ThisDrawing = objAcadApp.ActiveDocument
WhichDir = Direct1(dwgName)
ThisDrawing.Application.Documents.Open WhichDir & dwgName
Message 8 of 11
Yes Jeremy,
I did not think you have PartNum/NewPart in your database.
So the sample query is odd, but it should work all the same.
If you have any similar Column/Table, just try.
Our database is around 22 Meg and we have columns indexed.
There are about 120000 rows.
We also have it packed.
I have found that similar query:
SELECT DISTINCT ... WHERE x IN (SELECT y ...)
is a big fault with the Jet in Access 97 even on a small database.
Now we have Access 2000 with the same failure.
It never takes more than a few seconds if I use an ODBC driver
on the same query/database.
(Ex: ODBC = 4 secs / JET = 20 min+ and we could not wait)
You could try the query directly in MS Access.
The MSQRY32.EXE that comes with many MS products, takes only a couple
seconds.
(Aren't they all from MS ? I guess one team is busy doing the PaperClip
animation.)
Thanks for trying.
Message 9 of 11
Thanks I just bought it Now on Amazon.com
It is $35.96
use the isbn and leave out the dashes
ISBN 0766816400
Message 10 of 11
Sorry about that...
The [Tools] menu in question is in the VBA editor (VBAIDE) in AutoCAD 2000,
not under AutoCAD 2000 itself.
As for interactively... You could use the DBCONNECT feature of AutoCAD 2000.
(See the on-line help for further details.)
Until later,
Jeremy McMahan
Oject Library".)
or Visual Basic.
Message 11 of 11
Quan,
Yeah... It is usually best to test the performance in you specific
environment with the different options.
To be honest, I have not tested nested query performance using .MDBs and/or
the Jet engine. Most of my experience has been with ODBC and SQL
Server/Oracle. Even there a nested query can significantly degrade
performance. (I think it's because the engine can't use indexes on the
results of the nested query... but that's just a theory.)
You may also want to look in your SQL manual for information about the
"HAVING" operand. Proper usage of this can often improve query performance.
Until later,
Jeremy McMahan
> Yes Jeremy,
> seconds.
> animation.)
> Thanks for trying.
