Acces to AcadMText object problem
228549BQGUH
Observer Observer
228549BQGUH
Observer
Observer
Hi.
I can't access the MText object. What am I doing wrong? I'm trying to get to an MText object to be able to change a text string in it, or move it, or erase it. I can't connect to the MText object, even though I know the Index ID. How to acces to MText Box ?
Sub CreateMText()
    Dim mtextObj As AcadMText
    Dim insertPoint(0 To 2) As Double
    Dim targetPoint(0 To 2) As Double
    Dim width As Double
    Dim textString As String
    Dim s1 As Double
    Dim s2 As Double
    insertPoint(0) = 2
    insertPoint(1) = 2
    insertPoint(2) = 0
    width = 100
    textString = "mTextBox 1"
    ' Create a text Object in model space
    Set mtextObj = ThisDrawing.ModelSpace.AddMText(InsertionPoint:=insertPoint, width:=width, Text:=textString)
    s1 = mtextObj.ObjectID
    insertPoint(0) = 10
    insertPoint(1) = 10
    insertPoint(2) = 0
    width = 100
    textString = "mTextBox 2"
    s2 = mtextObj.ObjectID
    mtextObj.textString = "I don't know..."
    MsgBox "mTextBox 1 item number is: " & s1
    MsgBox "mTextBox 2 item number is: " & s2
    targetPoint(0) = 20
    targetPoint(1) = 20
    targetPoint(2) = 0
    ThisDrawing.ModelSpace.Item(s1).Move insertPoint, targetPoint
    ThisDrawing.ModelSpace.Item(s2).Delete
    ZoomAll
End Sub
Hi.
norman.yuan
[Object].Item() takes either a string or an integer as the index to identify an object in a Object collection. In collections like AcadBlocks/AcadLayers, items are indexed with string key, while in collections like AcadBlock/Model[Paper]Space, the items are indexed by integer numbers base, according to the item count of items in the collection.
While AcadObjectId is a number (long integer), it is NOT USED to key an item in a collection. That is why your code ran into error on line 38 and 39: you cannot use ObjectId as the index, and the index cannot be greater than the count of the items minus 1.
In you case, since your code created the MText (or any AcadEntity, for that matters), your code should hold a reference to it for later operation, if needed. That is:
Dim mtextObj1 As AcadMText
Dim mtextObj2 As AcadMText
Set mtextObj1=ThisDrawing.ModelSpace.AddMText(.......)
Set mtextObj2=ThisDrawing.ModelSpace.AddMText(.......)
mtextObj1.Move [pointA], [pointB]
mtextObj1.Update
mtextObj2.Delete
Norman Yuan
Drive CAD With Code
Ed__Jobe
When you add an entity using ThisDrawing.Modelspace.AddXXX methods, you can only set very few properties. By default, it is added with the "CE" or Create Entity variables, such as CELAYER, What you need to do is get the entity you just added and modify its properties to what you want. See the sample code below.
    With mtextObj
      .Layer = "A-ANNO-EXT"
      .AttachmentPoint = acAttachmentPointTopCenter
      .InsertionPoint =  new3DPoint
      .Width = 2
      .Update
    End With
Ed
How to post your code.
