Acad2005 Sheet Set name and path?
Message 1 of 1
Greetings,
How do you get the name and path of currently opened sheet sets?
I copied the example sheet set dvb provided with 2005 and appended the following code in a new sub.
Dim sheetset As New sheetset
Dim ssMgr As New AcSmSheetSetMgr
Dim dbIter As IAcSmEnumDatabase
Dim db As IAcSmDatabase
Set dbIter = ssMgr.GetDatabaseEnumerator
Set db = dbIter.Next
Do While Not db Is Nothing
frm1.ComboBox1.AddItem db.GetName 'this is wrong - results in an empty string!
Set db = Nothing
Loop
Kevin.
Replies (0)
