acad.lsp + acaddoc.lsp clash
I have read a lot of postings but I still can't quite find the answer to
this:-
I have a desktop icon which starts AutoCAD in a directory with the following
2 files:-
acad.lsp which contains the following
(defun S::STARTUP()
(command "_-vbaload" "StoreSpace.dvb")
(command "_-VBARUN" "Initialise")
and acaddoc.lsp which contains the following:-
(defun S::STARTUP()
(command "_-VBARUN" "Runsynchronise")
This produces the following error:-
"Command: -vbarun
Macro name: ShowFixtures Execution error"
and StoreSpace.dvb is not loaded.
If I move acaddoc.lsp, acad.lsp runs and loads StoreSpace.dvb but obviously
the ShowFixtures sub does not run, unless I move it back into the directory
after starting up AutoCAD in which case it runs on each drawing opening. I
don't understand why this causes a problem. I would expect acad.lsp to run
on startup then acaddoc.lsp to run on opening of each drawing.
Regards
Dave Preston
> 2 files:-
> (defun S::STARTUP()
> (defun S::STARTUP()
Your "S::STARTUP" function in "acaddoc.lsp" is overwriting
the same function as defined in "acad.lsp"
"Acad.lsp" loads first, defining S::STARTUP.
Then "acaddoc.lsp" loads, redefining S::STARTUP.
Put all your startup code in a function called "mystartup",
(in "acaddoc.lsp") and append it to S::Startup, in case it's
already defined somewhere else...
(defun-q mystartup ()
(this is my startup code)
(setq S::STARTUP (append S::STARTUP mystartup))
R.K. McSwain
http://rkmcswain.blogspot.com
Many thanks. That works perfectly
Regards
Dave Preston
"R.K. McSwain" wrote in message
news:5813787@discussion.autodesk.com...
> following
> 2 files:-
> (defun S::STARTUP()
> (defun S::STARTUP()
R.K. McSwain
Hmm. Although everything works perfectly I have just noticed that I get the
following error when starting AutoCAD if the acaddoc.lsp is present:-
AutoCAD menu utilities loaded.; error: Invalid attempt to access a compiled
function definition. You may want to define it using defun-q: #
@0f40ee38
S::STARTUP>
My acad.lsp contains the following:-
(defun S::STARTUP()
My acaddoc.lsp contains the following:-
(defun-q docStartup()
(command "-VBARUN" "Runsynchronise")
(setq S::STARTUP (append S::STARTUP docStartup))
> following
> 2 files:-
> (defun S::STARTUP()
> (defun S::STARTUP()
R.K. McSwain
You need to used defun-q for your s::startup too. This will allow the append
to work.
> @0f40ee38
> S::STARTUP>
> (defun S::STARTUP()
>> following
>> 2 files:-
>> (defun S::STARTUP()
>> (defun S::STARTUP()
Cheers Ken, I missed that subtle difference. It's not something I know much
about. That said, the first CAD programming I did was autolisp 22 years ago,
and not used it much since so a bit rusty now!
Dave
"Ken Krupa" wrote in message
news:5816824@discussion.autodesk.com...
to work.
> the
> compiled
> @0f40ee38
> S::STARTUP>
> (defun S::STARTUP()
>> following
>> 2 files:-
>> (defun S::STARTUP()
>> (defun S::STARTUP()
