A ListView question: GetFirstVisible
mdhutchinson
Advisor Advisor
mdhutchinson
GetFirstVisalbe method of a ListView control obtains a ListItem. It is in-fact the first item that can be seen at the top of the list box.
The FindItem method along with EnsureVisible works to automatically scroll the control so the item is visible. This is working well... but
Question: Does anyone know how I might use this to return the scroll to the same location it was at prior to the procedure.
Here is what i do. It also check to reselect a previously selected item after the rebuild of the list (Refresh type method)
[code]
'Get the Key of the selectedItem
Dim vSelIndex As Long, vTopIndex As Long
If MyListView.ListItems.Count <> 0 Then
If Not MyListView.SelectedItem Is Nothing Then
vSelIndex = MyListView.SelectedItem.Index
Else
vSelIndex = -1
End If
'Get the index of the top visible
vTopIndex = MyListView.GetFirstVisible.Index
End If
MyListView.ListItems.Clear
'Rebuild the List Content
'Reselect
Dim vLI As ListItem
If vSelIndex <> -1 Then
For Each vLI In MyListView.ListItems
If vLI.Index = vTopIndex Then
vLI.EnsureVisible
End If
Next vLI
If vLI.Index = vSelIndex Then
vLI.Selected = True
vLI.EnsureVisible
End If
Next vLI
End If
Set vLI = Nothing
[/code]
Try this out. I did not test it completly, but it should be pretty good. Note that I am using the index property to match, but you may use the KEY property......
Hope this helps.
