3 Dynamic attributes with the same dynamic block
Amremad
Message 1 of 9
Amremad
Hi every body
this question very important for me , i tried to solve it by my slef with 1 year along but i can't to find any solution for it
my problem
i have 3 attribute in one block , i made 3 options for visibilty1
so i need in visibilty (1) i can show only the text 11
and i need in visibilty (2) i can show only the text 22
and i need in visibilty (3) i can show only the text 33
see my attach and you will understand me
thx for ur help
Replies (8)
Message 2 of 9
hi.
i checked your bloc it work fine. But i dont know why all the att is show.
I have delete all your block and i have used the insert bloc --> i have only one attribut showed.
check the ATTMODE but i dont know why this.
Message 3 of 9
Amremad
thank you for you replay
this is my problem 3 attrubites show at the same time
Message 4 of 9
can you test with the var. system ATTREQ at 0 ?
or create a wbloc with you block and créate a new dwg and insert your bloc from the file.
Message 5 of 9
Amremad
I CAN'T UNDERSTANT YOU
CAN YOU MAKE A SAMPLE FOR ME
THX
Message 6 of 9
sr for my english : so.
1 - in command ligne : 'wbloc' press Enter and sélect your bloc inserted. check the name of the bloc in Name (in the new windows)-> save it. (see et1.pdf)
2 - Close the dwg and in the Menu File : New
3 - in the new dwg : command ligne : insert ENTER (sr for mee : inserer so try the command i ENTER)
--> in the windows click on the button Add (sr my acad is in French) (see Et2.pdf)
--> choose the file saved in part 1 --> Enter and insert it on the dwg.
if this works ok , but if not.. i dont know why.
Message 7 of 9
Amremad
did you understand my question ?
i think your solution is for inserting block but my question for how can i show two attributes in dynamic block with two visibilty options
i hope you will understand me
sorry for my english
Message 8 of 9
oh ok 🙂
So your reponse : You cant do this. Only one visibility at once.
Message 9 of 9
Amremad
yes only one attribute show in only one visibilty and so on
thx for your intersting
