2015 Crashes from VBA when callling vlisp function vl-vbarun with VL.app.16
lando7189
lando7189
I've never had a problem using the VL.Application.16 from AutoCAD 2004 thru 2014.  Now in AutoCAD 2015, it crashes without any kind of message.
To reproduce the error, cut and paste this code to a VBA module:
Option Explicit
Public Sub vlTest()
Dim vlApp As Object
Debug.Print "vlApp object declared"
''## Either way causes autocad to become unstable
Set vlApp = CreateObject("VL.Application.16")
'Set vlApp = Application.GetInterfaceObject("VL.Application.16")
Debug.Print "vlApp object assigned"
Dim vlDoc As Object
Debug.Print "vlDoc object declared"
''## The crash occurs here when run using LISP vl-rbarun
Set vlDoc = vlApp.ActiveDocument
Debug.Print "vlDoc object assigned"
End Sub
Test 1:  in the immediate window in the VBA IDE, run the macro. Should run an print 4 lines.
Test 2:  run from autocad command line using VBARUN and select the macro.  Again, prints 4 lines.
Test 3:  Cut and paste (or type) the following to the command line in AutoCAD:
(vl-rbarun "vlTest")
AutoCAD 2015 crashes trying to get the active VL document.  Even when debugging within the IDE, it crashes just trying to assign vlApp to a watch window when run from vl-vbarun.
Any insight would be greatly appreciated.  Thanks in advance.
Lanny
[AutoCAD 2015 sp2]
[64-bit Windows 8.1 Enterprise 64-bit (6.2, Build 9200) (9600.winblue_r5.141029-1500)]
lando7189
The above lisp function that crashes should be entered as:
(vl-vbarun "vlTest")
... then it will crash. Sorry for the typo.  - Lanny
lando7189
Issue is fixed in AutoCAD 2016.
Smiley Very Happy
AdrianSaf
Anything new on this for AutoCAD 2015? Any service patch or other fix?
Alfred.NESWADBA
maybe that helps:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
AdrianSaf
Yes, that fixes the issue. Thank you.
