Vault Local Workspace Cleanup tool.
When you work with Vault you download lots of file to your local workspace (read only).
When you close the files in Inventor, these files stay in your local folder.
After working for a while with Inventor/Vault you need to cleanup the local workingfolder.
But how do you know which files can be deleted?
Therefore we need a LocalWorkingFolderCleanup tool.
This tool should scan the local workspace used by Vault (based on a projectfile).
As result this tool should show all the checked out files and all the file which are not saved in the Vault.
This tool should give you the possibility to check in the files into Vault and delete all the read only and unused files in the projectfolder (not in the libraries).
