Use boolean expressions in searches
I like to use boolean expressions in searches.
For example:
(file name = "bracket") OR ( (file name = "lifting eye) AND (state = 'released") )
This would give me all brackets and all lifting eyes which are released
16 Comments
dvsmiller9
I agree we need 'OR' as an option.  Currently just being able to 'AND' criteria is limiting.
dvsmiller9
This would also be helpful in Category Rules assignment.  We have a semi-intelligent part numbering system where the first few digits define the category.  Some have categories have overlapping prefixes (fixtures with different prefixes due to legacy assignment or running out of sequential numbers within a prefix group - hey, I only inherited the system) where a boolean assignment rule would allow me to assign multiple prefix groups to one category.
ihayesjr
Status changed to: Accepted
Thanks for the suggestion, can you look at the wiki help topic to see this already addresses what you are looking for? http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0003-Essentia3/0017-Searchin17
Like mentioned above I am missing the OR  operator. And when havenig a AND and an OR operator there must be something like a group function as wel to bond them together.
Currently the saved search criteria acts as an AND operator.  There is no OR operator in the saved search criteria.  It would be nice if there was a way of implementing a search criteria similar to that of the filter settings.  There is a lot more functionality in the Filter editor than in the saved search criteria.  I can create much more complex searching criteria with this.
This search would then return:
  • BRT Parts of EXTRUSION NO - ACS100334
  • FST Assemblies
  • HZH Parts of EXTRUSION NO - ACS100306
Currently you would have to have 3 separate saved searches. one for each AND line.
Tags (2)
I am asking for this since I use Vault. It would be a great step forward when boolean operations can be created in a search definition.
Maarten Weers
Technical Specialist CAD
Parker Hannifin
olearya
Hi there,
Thanks for submitting your idea - would this existing request resolve your issue?
http://forums.autodesk.com/t5/vault-ideastation/use-boolean-expressions-in-searches/idi-p/3551524
@olearya the existing request would simply add the foundation for complex searches.  But I would prefer a more user friendly approach.  Trying to create long complex searches in a single line box can become tedious.  I like the way the filter dialog is laid out and shows you a structure.
(It only took me a year to get back to this)...
olearya
Better late than never Steve 🙂
philip.s
There is no easy way to search for files where Field1 or Field2 or Field3 = "some string"  SQL can do this, and the vault is built on SQL.
https://forums.autodesk.com/t5/vault-forum/what-is-query-builder/m-p/7833029/highlight/true#M72385
contains a workaround, but it is awkward and cannot be saved.  We need better search capabilities.
Tags (3)
ihayesjr
There are 4+1 searching methods, but no one is complete. Could be fine to have only one or two method but completed with boolean expressions and flexible options. If you use 5* on quick search (token searching tool) you do not get ISO Standard results (everything start with 5).
ihayesjr
ihayesjr
Implemented in Vault 2027 with the Autodesk Assistant
