I didn't find this in the ideastation yet, so I'll add this.
We came across an annoying feature in certain tree structures within Vault.
For instance when you open the attachements in the 'Uses' tab of a masterfile, you get a giant list of all files under that file.
I asked this question on the forum, but it was seemingly impossible to controle the behaviour of the tree structure without having to result to programming...
It would be a usefull feature if you can choose wether the tree structure is open as standard or closed as standard.
At this time it's always open... And that means a lot of work when you are trying to get a good overview of the structure.
As you can see, all the files are open... So we would have to manually close each an everyone to get a good overview.
It's would be so much easier to have a function where you can choose if the structure appears open or closed like this:
If you have noticed this problem to it would be great to have your support.
Thank you!
grts, Wouter
