The current property editing dialog in Vault overwrites all property values as a static string regardless of how the value is determined in Inventor. End User currently can't see in Vault if a Property Value is a result of a Formula driven by geometrical Parameters from the Inventor 3D Model or just typed as a static string value.
Unnoticed overwriting of function properties with static string values has caused many errors and repair work in our company.
The property editing dialog in Vault should look similar to Inventor and have the "fx" button next to the value input to switch between the function definition and its output.
Vault should edit properties with a "Function" in the same way as in Inventor, without overwriting as with static text.
