See Xref State in AutoCAD
I have an enhancement request for the integration between Vault and AutoCAD.  Within AutoCAD, we can use the Xreference palette to see some aspects of the Xrefs' status in the vault.  It would be quite useful to see the Xref state.  I do not see a way to display the state column in the Xref palette.  Could this be customized to allow users to add this as a column?
Thank you,
Mark Cloyed
IMAGINiT Technologies
3 Comments
ihayesjr
@mark.cloyed
Thank you for posting the idea. However, we have added the ability to show the Vault details of the files, including the xRefs, in a Show Details palette. Have you tried this?
mark.cloyed
@ihayesjr - thank you for pointing this out.  It does fulfill the client's needs using the Uses tab.  Unfortunately, they are still on 2021, so I have suggested they upgrade to the current versions of AutoCAD and Vault Pro to take advantage of this.
Thanks again,
Mark
ihayesjr
