Saved Searches for Thin Client
Hi
Please consider adding capability to thin client (similar to thick client) where advanced searches can be saved for re-use
This functionality would be very useful if
1. this can be customised/saved by the local client
2. customised/saved by the Vault administrator and available to all users on log in to Vault Thin client
Max Bodnar
11 Comments
This is another issue that is adversely affecting our users.  Having to go back in and put in the same search details each and every time is time consuming for users who are often searching on the same data regularly.
Gene.R
yes, also please add the Boolean Operators, OR AND NOT " ", to the basic search as it was in the previous thin client, this is a huge time saver for searching 2 or more known part numbers, primarily the OR operand has been used heavily like 1006000 OR 1006001 returns just those 2 items.
AutoCAD LT license is a great advantage for small entrepreneurs to strat their business. BSB CADD AutoCAD Institute in Hyderabad helps users to learn all features.
wim_de_winter
A thin client API can be usefull to create custom search fields.
dsl145
OMG yes please add this functionality!!!
The typical user for Vault Thin Client is NOT a power user and its hard enough to get them familiar enough with the idea of Vault in the first place that having to type in your search filters (via Advanced Find Results) every time they start up is just horrible.
To add to this a bit, even being able to add to your existing advanced find result filters would be a welcome improvement.
In my company the admin searches are deployed on the other posts but it would be nice that Vault manages this: admin searches and personal searches
YounesYammouri
Could be useful to improove one search tool only, not to have 5 different search methods, each one that do not do what you need. An AND construct could help in searches. Simplify the scroll down searches menù please.
ihayesjr
You can save Advanced Searches as browser bookmarks to re-use them again.
Dan_Margulius
Hi Irvin,
The bookmarks is a browser solution and not a Vault one.
I think we should still have this feature(save search in TC) in the Vault thin client application, solution form Autodesk.
Dan
ihayesjr
@Dan_Margulius Why does it matter how it is done if it still solves the problem?
