I'd like to the ability to save Revision Row contents between every revision bump regardless of released versioning.
Currently when a revision is bumped, unless the previous revision row was "released", the row is overwritten.
As an example: Revision 0 was active the last time the document was "Released". The next project may have 5 different revision changes prior to it being released again, and this is the result:
All information between 0 and 1.5 is lost.
During this project example. The secondary revision level was bumped 5 different times, but each time the secondary revision was bumped the row was overwritten and the descriptions of what happened during the previous 4 bumps is lost.
The only way to make these rows stick at every bump would be to release the print at each one of these bumps. This is not possible during many design processes. During development phases I need to track changes to a document before it's actually released.
As one example:
A designer designs a component and this document is sent out to a supplier for quoting purposes. During communications with the supplier, some modifications to the component are deemed necessary. The designer will then make these changes to the document and re-submit the quote with a new revision level. It's possible that this document may be updated multiple times during the design process prior to the document being released. (Our company uses secondary level bumps during the design phases and primary level bumps for each document release)
We lose an awful lot of design information in our revision blocks because I'm unable to simply choose to save rows at each bump.
