REPLACE FROM VAULT
REPLACE FROM VAULT
I'd like to see a REPLACE FROM VAULT option when in an assembly and I RMB on an item, select Component, then select REPLACE FROM VAULT.
12 Comments
It is there already...
Thanks. Not entirely intuitive but it's there. I'd still like to see it in the position indicated. For the developers it's 1 more entry and then direct to the Select File From Vault window.
kwilson_design
Pretty straightforward here. I would like to see a "Replace from Vault" option when replacing components in an assembly. We can replace from local and Content Center but not Vault upfront? Currently users have to select Replace or Replace All and the dialog box opens we have to select the little Vault icon in the lower left corner to open up yet another dialog box where we can browse the Vault. It would be nice if Autodesk would add this because it would save us from more dialog boxes and clicks.
See below...
iangoh
This make sense as I always need to click replace then click "From Vault" which can be very tedious from day to day operations
YounesYammouri
Status changed to: Accepted
It'd be great if in an assembly (.iam) under the Component/Replace option there was a Component/Replace from Vault option. Similar to how the Vault toolbar has the Open from Vault option, or the Place from Vault option.
There is, but I'd like a more direct option also. Duplicate of this idea https://forums.autodesk.com/t5/vault-ideas/replace-from-vault/idi-p/3929704
limin.chung
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute/validate then please apply for access using this link:
Limin
Replace component from vault option as well as replace component from local.
Tags (1)
Uwe_Lindner
Bitte benutze den Vault Data Standard.
jingyi.liu
Hi
Thanks for your feedback, the idea you request has been accepted by Vault Team, please refer to below in Vault Ideas Forum.
Jingyi
YounesYammouri
The request has been implemented and is available with Autodesk Vault 2019.1 Update:
http://help.autodesk.com/view/VAULT/2019/ENU/?guid=GUID-2E9AD84E-1EFA-4AA2-9D4B-D716DFDA22B1
Replace from VaultReplace from Vault
