Hello all,
When I check in multiple Inventor files using Autodesk Task Scheduler, the "create visualization attachment" is checked by default and dwf's are automatically created in Vault, see attached.
Autodesk already confirmed that there is no way to permanently disable it. I don't need a mass create dwfs process so I need the default to be off.
In Vault I already turned off creation of dwf files (Tools / Settings / Vis Attachments / Define - not enable.)
Search in Forum for more details and I will post this on Inventor Idea site as I'm not sure what division can fix it.
Until this issue is fixed, we need to manually delete all Vault dwf's created by task scheduler.
Thank you for your help and vote.
radu
