Show only
Search instead for
Sarebbe ottimale avere la possibilità di selezionare i file dipendenti di un assieme, sia ipt che idw corrispondente, in particolare perché per il comando " archivia " già esiste questa opzione :
si tratta semplicemente di attivarla anche sul comando " Apri file "
@ihayesjr, because what if they're NOT inventor files (e.g. selecting multiple PDF's and wanting to open them all up).
Moreover, I like to use the Vault Thick Client as my 'browser', i.e. as a Windows Explorer replacement. Vault is very handy at sorting and filtering and searching.
Actually, you've already seen this comment here: Ideas.../8400977.
Please add this feature. It is regular practice to check all (or at least most) assemblies in the Where Used tab when modifying a part to ensure compatibility with existing designs. This feature should have been present on day one, frankly. Even File Explorer can do this.
Currently when selecting multiple files in the vault the "Open" option is greyed out. Having the ability to open selected files at once instead of individuality has some advantages. The majority of engineers considered this not very efficient for them to quickly access files for swift assessment of designs. Unless there's another alternative to achieve this action.
for the workflow it would be very convenient, if we could select and open multiple drawings / parts at once. The subsequent dialog box for checking out parts, would apply to all selected ones. It could save us a lot of time.
Would be very happy, if you could add this feature, in the near future.
If anyone wants the workaround i use. I take Get on all files i want. I go to the folder they are at. Open all from there. Then go back to vaul and select all files then checking them out
