キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
Open Vault API to ilogic
Can't believe this is not listed as an idea, I must be searching for the wrong text.
Why can iLogic not access Vault properly? Absolutely crazy.
Most important missing feature is the ability 'get' files, it breaks so many ilogic workflows by not being able to bring files down to a users machine. Also, auto-check-in would be good.
6件のコメント
適用対象外
This is what you are looking for:
https://github.com/koechlm/iLogic-Vault/tree/2020.2.0/iLogic-Vault
I fully agree, should be the standard in iLogic.
ThomasRambach
https://github.com/koechlm/iLogic-Vault this should be considered implemented from what I understand.
khoskins
I agree it would be nice to have this implemented as default functionality, but it is possible to use the Vault API within iLogic. You add the Vault DLL's as references in an iLogic rule. You can then use the Vault connection created by the Vault Add-In within Inventor so you do not duplicate connections.
I wish this was better documented but you can piece it together with existing iLogic functionality.
hugo.trepanier
This is a must to have and personally need to be implemented by Autodesk inside Inventor Ilogic in the top of the list.
d_stockinger
ihayesjr
変更されたステータス: Implemented
This was implemented in the Inventor 2024 release.
お探しの情報が見つからないときは、コミュニティで質問しましょう。困っている人がいたら、情報を教えてあげましょう。
アイデアを提出
