Move files and include dependants
If you move an assembly/drawing in Vault to another folder, there should be an option to collect and move dependant files (uses) along with the move.  Currently a user needs to manually find (which isn't easy) all dependant files of a parent and move them separately to the destination folder.
An option to move all or no dependants with the parent should be available.
42 Comments
matt.jamieson
This idea is 10 years old and is STILL not implemented. Come on Autodesk, sort it out.
cscheck
The lack of this functionality in Autodesk Vault is embarrassingly behind curve. It results in frustration, confusion,  and lost productivity for our Autodesk software users on a regular basis.
Please resolve this!
peter.kapitola
How is this not a thing already. Come on, Autodesk.
vandoren.david
This topic pops up about once a month and every time I think "this would be so easy to implement", but then started to think of all the failure modes.  What about library files? Content Center Hardware?  It'll need to be something similar to 'Design Copy' but instead a 'Design Move'.
peter.kapitola
@vandoren.david
It seems pretty intuitive and obvious to me that Library and Content Center files would stay put. Are there other failure modes?
But yes, a "Design Move" interface would make it clear where everything is going.
PainshockAman
Observer
(view in My Videos)
Hello
Here, in the Vault 2024 program, I show that there is no function for moving the assembly and child files. It is also necessary to take into account, if this feature appears, that some files as part of this assembly may be library files.
We are subscribers of Autodesk products and we have the impression that Autodesk is not going to develop its products! This feature was requested 10 years ago and you didn’t have enough strength, money and time to implement it??? Your competitors have had these functions for a long time and are moving forward. You guys are stuck in the distant past, your competitors in CAD and PDM have surpassed you in the functionality and usability of their products. Looks like you're saving ideas.
In conclusion, I will say that if Autodesk does not improve the products, we will refuse them!
peter.kapitola
We would have left Autodesk products a few years ago if not for all the existing models we have that are in Inventor format.
It's pretty sad when "vendorlock" appears to be the key customer retention strategy.
I agree. I can't believe AutoDesk would have all this input and yet not use any of it. They are truly falling behind.
vandoren.david
Few months shy for this request's 10 year anniversary.   I see the ECO feature has an "include related files" when add files, but cant apply the same to move command?  If this isn't going to be done or even considered, can we just get a "We're not doing it" from Autodesk?
NeilT3D
Observer
Can't believe it's been 10 years since I put this request in.  Vault is a data management product and this is a fundamental data management feature, I'm staggered this still isn't possible.
martin_caslingSJC3K
Can't agree more. The ability to move a top assembly along with all its constituents is a must. Surely this should be added by now!
ihayesjr
Status changed to: Accepted
georgiaGP5JJ
It would be really useful to be able to move the parts that are used in an assembly but are in different folders at the same time from the 'uses' screen in vault.
Example - looking at the parts used in an assembly and they are located in various folders. Go to the uses panel and select all the parts used within that assembly and be able to move them to another location from there.
CDuPlessisTQEZQ
Now in a situation where I need to find depended drawings of parts and assemblies inside of another folder full of other parts and assemblies and drawings... It's tedious to try and move 1 assembly with all of it's children components and their drawings to a different location. I still hope that is would be implemented at  some point. It might not be a tool you use everyday, but it says you hours of tedious sorting. It's been 17 years now since this post.
https://forums.autodesk.com/t5/vault-forum/moving-an-assembly-file-and-it-s-children-in-vault/td-p/2...
ihayesjr
@CDuPlessisTQEZQ
Thank you for your feedback. Please make sure you are part of our Feedback community. We will be discussing this feature in an upcoming webinar.
vandoren.david
I feel all of these issue could be resolved by allowing the user to choose files from the "Where Used" or "Uses" tab and drag+drop into a folder.
chrisBHCMT
Has this been resolved?
I have missed the webinar.
@ihayesjr
@CDuPlessisTQEZQ
Neil_Cross
@chrisBHCMT I'm not sure whether it is or isn't, but I've went and done it myself and wrote an extension that does this.  It's almost finished, but I'm not sure how I'm gonna distribute it yet, but pretty soon it'll be done.
chrisBHCMT
Neil, thanks for the info. Please let me know asap when you get it done. I'll happily be a beta tester. Im a recent convert to Inventor and there are some real tiresome issues.
--> Solid works and Pro-E had this solved years and years ago.
Neil_Cross
@chrisBHCMT Will do.  I'm currently working on extending it into having a copy design style interface where you can either move everything to a single folder, or individually assign each child file to be moved to different folders.  It's one of a few new tools I'm creating as part of a productivity suite, but I'll come back here when it's ready for testing 👍 cheers
