Lifecycle: Property set/trigger for State-Change -set a property at state change
Hallo Vault Team,
in connection with Autodesk Vault lifecycles and state changes it would be helpful to have a possibility to set triggers or for example property-sets!
In Vault there is already a possibility to set criterias at a state transition - for example "it ist not allowed that the property with the name "title" is empty".
In other words: The functions in the"Actions" tab should be advanced
Criteria/Kriterien tab:
Actions/Aktionen Tab:
The first possibility would be to integrate a possiblity to set properties here.
Property set/trigger in a new tab:
Here in this tab it would be heplful to habe the same possibilities to set or a similar view like in the "criteria" tab.
Example 1:
In an example at the change-state-change from "approval" to "released" I want to define hat the property "Approval-state" should get a fixed value "approved" or the property "approved" should get the value "Yes (Boolean)".
Thanks for your interest in my idea -- if there are any questions please don't hesitate to contact me!
Dominik
7 Comments
Absolutely!!
This may be blasphemy, but Solidworks PDM Professional has had this ability, and several others, for quite some time. There, a simple approval click does it all automatically: change states, bump revisions, set properties, map approval signatures based upon the approvers user login. Very quick and very easy to configure to just about anything imaginable.
dominik.gleinser
Hallo Jeff,
I think my examples are not the best ones, but I think there are several other use cases for such a feature.
Also a Event Cather at some tasks would be nice!
Thank you for your reply and the description!
Dominik
This is defiantly a feature I would like to see, however this has been a requested feature since 2012 minimum, So I'm not holding my breath.
https://forums.autodesk.com/t5/vault-ideas/must-to-have-in-the-lifeccyle-engine/idc-p/5658229#M2799
https://forums.autodesk.com/t5/vault-ideas/enforce-property-write-on-lifecycle-transition/idc-p/4318...
To get this sorted for my company I had to learn how to code, and write my own extension. Your free to use it (link below), changing the properties you see fit. I am contemplating putting a UI to this, and make it available for others via the app exchange.
https://forums.autodesk.com/t5/vault-customization/set-property-value-at-lifecycle-transition/m-p/76...
up
dominik.gleinser
Any news regarding this idea?
Bump!
