Hide disabled users
Hide disabled users
Autodesk,
We have a customer that would like to hide disabled users for easier administration.
Eric Miller
Applied Engineering
26 Comments
douthett
Part of my duties to add, modify or make inactive different users account inside of Vault because of this I'm in user management window every day.  Now what I would love to have is a filter for this window so I can set it not to display those accounts that are inactive or to filter the user names.  While we can sort by whether or not the account is enable, it just makes more since to have a filter.
If we can't have a filter, how about a search option?
Tags (2)
smilinger
I think this idea can also be think as a duplicate of this one:
Customize every grid
http://forums.autodesk.com/t5/vault-ideastation/customize-every-grid/idi-p/5711732
After all, it is also a grid, isn't it?
johannes.bauer
Autodesk Support
As a workaround you could CTRL+F and search for Yes.
That will filter all your 'enabled' no entries
YounesYammouri
YounesYammouri
YounesYammouri
We add a filter capability using CTRL+F to many dialogs in Vault Client including User Management, Group Management dialogs in Vault 2016 release.
Younes
scottwayand
When adding users or groups to lifecycle definitions, other groups, or other settings, do not show disabled user or group accounts in the list.  Or put a check box to only show enabled accounts in the lists.
For large companies that have many ex-employees with disabled accounts, this would speed up the process of selecting users by removing them from the list.
ThomasRambach
If you ever create a group or user in Vault and then disable the group because you no longer need it or if a user leaves the company, the group and user always remains visible in the lists. I would like the ability to filter out permanently old groups and users. It would be nice if you have to deliberately click something else to be able to see old groups and users without having to see them each time you view the lists. The clutter gets distracting.
Also, would be beneficial to be able add a description to a group name and display it in the columns for more information.
ihayesjr
@ThomasRambach, try using the Ctrl+F key in the Users or Groups dialog.
ihayesjr
ThomasRambach
Control+F searches but it doesn't allow you to hide all inactive groups or users.
ihayesjr
Try typing "Enabled = Yes".
Or simply "Yes"
But the request is Permantly Filter out. So for example a check box which you can check if you only want to see the Enabled Users or Groups.
ihayesjr
ThomasRambach
@Anonymous that's right. A permanent solution to hiding unused users and groups is desired, I don't want to have to do it every time I look at the screen.
I have renamed each departed user with the same prefix "xxx".  This puts them near the bottom and if would like them to be at the bottom "zzz".
ihayesjr
Geveke
It would be nice if users that are no longer active are moved to a separate tab (inactive users) automatically, if their status is changed (and vice versa). This will keep your list of active users clear, especially when you face a large staff turnover. Must be quite easy to implement and could be part of a servicepack (perhaps 2019 sp1 ??).
dpeters3
I need to see how many users are actively assigned to each of 5 different vaults on one server.  If I list users I can filter on enabled = yes.  If I change to "by vault" I can see what users are assigned to each vault, but the enabled column is not shown so this can't be filtered.
Suggested changes
Either put a "column chooser" in the users dialog, so the enabled column can be shown in this view
or
Put a "show only enabled users" checkbox in the dialog.
b.graaf
Very usefull option!
The ctrl + F is also nice and new to me, but a permanent option with a hide button would be better!
