For Vault Numbering Scheme Skip Lock option
For Vault Numbering Scheme Skip button Lock option from vault.
as if we have  this skip option in that case users are skip this and crate number what they want.
in vault we should have option do you want this skip button yes/no. so that admin can decide base on the requirement.
1 Comment
philippelandry4954
When you create a new document within AUTOCAD or INVENTOR, depending on the VAULT setting, you will get the automatic number dialog to select the correct scheme. If the selected scheme is based on chrono, you will get the following number. The next step will ask the user to select the place where to save the file. But the user can modify the file name that VAULT proposed. Even if the database is set to use the unique file name, if it does not exist, the user will be able to save the new file in VAULT. However, at a time when another user will create a new document, the system may propose the number already used and forced previously. Then an error will occur.
The idea would be to block any user to force the file name by adding an element when you create the numbering scheme. For example a check box to avoid the user to change the file name. In this case, instead of displaying the dialog box with possibility to change the name, just use the dialog showing the folder where to save the document.
Up to you to define another way, but forcing the file name whereas it was proposed by the system is difficult to manage.
Thanks.
Best regards
Tags (1)
