ECO - UDP constraints
Property constraints - like Enforce List Values = True, Value = Required are not applicable for ECO properties. Customers leveraging ECO workflows on a day-day usage would benefit from mandatory properties or all other constraint options known for FILE, ITEM, and CUSTOM OBJECT entities.
4 Comments
Hunteil
I can't believe this is not a feature yet. Other ECR/ECO/ECN programs allow this type of control out of the box. We need systems like this to help keep data uniform for downstream users. Otherwise as we've all most likely experienced at some point, engineers/drafters/users will take shortcuts to ignore the minimum requirements. Please add this.
kerrild
@Markus.Koechl
We use UDPs and Requires Value - set to true doesn't actually work.
This was actually reported by someone years ago to Ideas but archived:
https://forums.autodesk.com/t5/vault-ideas/eco-properties-don-t-follow-the-rules/idi-p/5318891
The whole ECO process badly needs an overhaul.
Markus.Koechl
Vault 2024 Update 1 implemented UDP constraints:
ihayesjr
Implemented in 2024.1 Update
