ECO title requires value / making the actual property settings work
Idea: If the property "Title (Item, CO)" has the setting "Requires value" as "true", no ECO should be producable without a title. Or at the very least it should not be able to change state.
The title of ECOs is a normal property, but the settings like "Requires value" or case sensitivity (See also, this Idea) don't seem to be doing their work. So the idea is simple: Make it so that if I check "Requires Value" at the property settings of , it produces an error if someone doesn't put in a title. And if you're on it, make all the other property settings work properly as well. Thank you.
2 Comments
In addition to that: seems that every property you define for ECOs ignore the "Requires value" setting (!). So it is not limited to the "Title" of the ECO...
WouterBreedveld
Also running in to this issue in a 2023 environment. In my opinion this is a bug...
